Introduction: K'nex Ruberband Gun
This is my k'nex rubberband gun that can shoot up to 7 rubber bands at once. It is really simple to build and use. If you have k'nex and rubberbands you can build it. Hope you like it.
Step 1: Collect the Pieces
Collect: Key: connectors connect together with rods
1 rubberband for the trigger
16 Small Green Rods
9 white rods
3 Blue Rods
5 Yellow Rods
2 Red rods
2 Gray Spacers
11 Light Blue Spacers
4 gray single connectors (next to the white rods)
3 light gray connectors (below the small green rods)
1 red connector (below the rubberband)
6 green connectors
3 white connectors
6 yellow connectors
4 orange connectors
3 black tiny rod/connector (next to the light blue spacers, below the white rods, and above the purble connectors)
2 Blue connectors (connects to the Purple connector)
2 Purple Connectors (connects to the Blue connector)
Sorry, my picture is a little blurry.
16 Small Green Rods
9 white rods
3 Blue Rods
5 Yellow Rods
2 Red rods
2 Gray Spacers
6 green connectors
3 white connectors
6 yellow connectors
4 orange connectors
Step 2: BUILD
Place small green rods all around white connector.
Step 3: BUILD
Use 2 small green rods to attatch 2 yellow connectors and 2 small black rod/connectors.
Step 4: BUILD
Look carefully at the picture in order to understand how to build it.
Step 5: BUILD
Build the trigger.
Step 6: BUILD
Put the trigger on to a yellow and the red rod.
Step 7: BUILD
Build the Handle.
Step 8: BUILD
Finish the Handle.
Step 9: BUILD
Put the rubberband on the trigger and down to the handle.
Step 10: BUILD
Finish the top of the gun.
Step 11: BUILD
Finish your gun.
Step 12: Loading Rubberbands
Run Rubber as many rubber bands as you want through each small green rod on the rotating barrel and to the end of the gun. Press the trigger and it should shoot all the rubberbands loaded at once.
