Introduction: K'NEX AUG A3 M1
The Australian built AUG is a renowned firearm known mostly for its unique styling and controls. Today, the iconic built in scope seen on the first generation A1 model was replaced with RIS, a step towards modernizing the rifle. A3 models utilizing this new flat top rail system would get another installation, the M1 variant. Combine these cosmetics with the use of a two stage trigger mechanism and you'll have the recipe for one very awesome rifle. My K'NEX AUG A3 M1 is a faithful recreation of the real steel firearm.
Below is an approximation for the parts needed to build 1 gun, 1 magazine, and 8 bullets:
Yellow connector: 115
White connector: 37
Green connector: 40
Red connector: 47
Gray connector: 70
White rod: 195
Blue (white rod length) flexi rod: 8
Small little green rod: 436
Tan clip: 25
Gray spacer: 19
Blue spacer: 25
Male ball joint: 7
Female ball socket: 12
Orange connector: 70
Small little black Y clip: 40
Blue clip: 27
Female hinge connector: 18
Male hinge connector: 16
Blue 3d connector: 6
Blue rod: 23
Gray 3d connector: 2
Double connector: 24
Orange 3d connector: 2
Long black or clear rod: 2
Gray endless X rod: 6
Yellow rod: 3
Small little black cap: 13
Micro (2 way) purple con: 2
Size 33 rubber band: 8
Size 32 or 33 rubber band: 3
Step 1: Instructional Video
Follow the tutorial to build a functioning replica of the AUG A3 M1 assault rifle with your K'NEX pieces! Featuring a semi auto firing mechanism, true trigger, 8 round removable magazines, this gun can achieve ranges of 40 feet while using gray connector ammo w/ size 33 rubber-bands.
