Introduction: K'NEX Škorpion Vz. 61
I've always had a soft spot for the Škorpion vz. 61. I just think it is one of the coolest looking sub machine guns ever built, especially when equipped with a suppressor. My main goal was to get the gun to look as close as possible to the Czechoslovakian machine pistol while trying to optimize its internal components.
Below is an approximation for the parts needed to build 1 gun, 1 magazine, 1 pin, and eight bullets:
Yellow connector: 33
White connector: 10
Little green rod: 134
White rod: 46
Small little black Y clip: 92
Small little orange 3d connector: 6
Orange conector: 22
Red rod: 2
Blue clip: 14
Blue spacer: 16
Gray spacer: 11
Red connector: 26
Gray connector: 25
Female hinge connector: 13
Long black rod: 5
Black rod connector lock out clip: 2
Double connector: 10
Tan clip: 27
Blue rod: 7
Green connector: 8
Black rod end cap: 7
Blue 3d connector: 2
Male ball joint: 5
Female ball socket: 5
Male hinge connector: 1
Yellow rod: 1
Blue flexi rod: 2
Small (white rod length) blue flexi rod: 2
Black wheels: 4
Black 1" tires: 9
Micro (3 way) yellow con: 2
Micro tan Y clip: 4
Micro to standard con: 1
Micro gray rod: 3
Micro small black rod: 3
Micro (2 way) purple con: 1
Size 16 or 19 rubber band: 2-3
Size 32 or 33 rubber band: 1
Size 117b rubber band: 1-3
Step 1: Instructional Video
Follow the tutorial to build a functioning replica of the Škorpion vz. 61 sub machine gun with your K'NEX pieces! Featuring a standard pin firing system, true trigger, 8 round removable magazines, this gun can achieve ranges of 40 when using a good pin & rubber-band set up.
