Introduction: KNex Sniper Thingamabob V2
THis is My Second version of my original sniper (https://www.instructables.com/id/Knex-Sniper-Thingamabob/) It now Features:
A true Tigger
BEtter Stock
Better Barrel
Forestock (adjustable)
Stats:
Range: I got 38 Ft at a ~ 15 Degree angle
Length: 2ft (Full Version) 1' 8" (Compact)
Height: 4in
Weight: ~100-200Grams
Accruacy: 2 sq. In. from target ( if you look directley down the sights)
Step 1: The Stock
THis The STock (You KNow, The Butt?)
Pic1: Make this
PIc2: Make this
Pic3: Make This
Pic4: Another Veiw
PIc5: Connect
Pic6: Connect (finished Product)
Step 2: Hanlde+Trigger
This is the part that you hold on to remembered? Im sorry if you cant make this from two pictures.
Step 3: Main Barrel
This Is where the trigger will be inserted and the pin wil go
The Firing Pin is a purple 3-D connecter connected to a black rod with tape.
P.S I dont like to take sections apart like this so i think you can make it from the pics provided.
Step 4: Attatch Ment Barrel
This is the barrel to make the full verision you do not need it if you want the compact version only.
pic1&2: Make
Pi2: Make (wierd peice)
Step 5: Forestock
THis is the forestock for the full verison
Step 6: Assembly
Time to assemble the gun
PIc1:attach stock to handle
pic2:attyack barrel to handle
pic3: attach extened barrel to main barrel
pic4: add Wierd peice
pic5: Add forestock
Step 7: Rubberbands
Trigger bands: See Last step
Firingbands: PLAce where ever you wish
12 Comments
12 years ago on Introduction
Great instructions, on the other hand i built it and sucked
what if you don't have the panel pieces.
Reply 12 years ago on Introduction
if u dont have the panel pieces (which i dont) then use rods instead to diagonally join pieces toghether.
you can make 2 of pic:2
13 years ago on Introduction
the bit at the front is called the foregrip but apart from that great instructable
it would look awsome if there was a long barrel and maybe a mag
14 years ago on Step 5
please show us another view
Reply 14 years ago on Step 5
READ NOTES
14 years ago on Introduction
how can you shoot
Reply 14 years ago on Introduction
pull hte pin back (purple connector on grey rod) put a bullet dont the barrel (any size rod). and pull the trigger
MUCH MUCH BETTER!!!!!!!! 5*s!
great ible and pics =]
btw it's foregrip not forestock =]
Looks rather simple, But great instructable and pictures!!
