Introduction: KP Point Welder
This a story is about how I made a point welding transformer.
I found an old E-form, 220/24V transformer which had as secondary winding a wire 3mm in diameter. The idea was to replace that with a different winding.
Disassembling was easy. First, I tried to get a smaller number of windings on secondary and test if I can get greater amp output and lower voltage. I read somewhere that voltage in this form of welding should be from 1.5V up to 6V and amps as much as possible.
Step 1: Rewiring the Old Transformer
I made a wooden mold to help hold the old primary winding. Using the old secondary copper wire (3mm dia) I wound a double parallel winding over existing primary coil. This gave me about 6V on secondary side and test showed that it was not enough power to melt 1 mm steel wire. Additionally the transformer became very hot very fast.
Step 2: Triple Parallel Winding
I tried the same trick but used 3 wires parallel which is equivalent to 21 square mm. Voltage measured 3,84 V on secondary side. I started to assemble all the parts on a board and I started to make end copper connections. I was sure that I got what I wanted from the beginning - Dear Murphy!
Still It was not enough amps.
Step 3: Test Board Misc.
I made a simple construction (test board) to find out how this work. Micro switch was inserted on the top level in a small walnut wooden box (lacquer comes later). Lower electrode was mounted on a aluminium square rod.
Step 4: A/mm2
Finally, I bought a length of 60 mm2 copper wire, removed the insulation and got a smaller diameter. I wrapped this wire with common thin scotch tape. The goal was to put 4 windings in transformer. Insulation was ok because between each loop is max 0.7V. In the end I got 2,54 V at the terminals and hopefully plenty of amps. I finished the new copper terminals for the secondary winding as well.
All this was finished after I went back to read, study and learn from the beginning (see step 7).
Repetitio mater studiorum est!
Step 5: Succes!
I got enough power. About 2.5 V and almost 70 Ampers! 1mm steel wire burned out in seconds. But switching it on and of manually is not accurate. I constantly burn out thinner material.
Sometimes the weld was perfect, but Murphy does not sleep!
Step 6: Intermezzo
In the meantime I needed to weld a small chimney for my tent stove.
I used my welder as is and successfully, hand pressing switch, I made from tin cans 12 cm diameter a smaller 6 cm diameter tubes.
I used an aluminium tube 3 cm in diameter as lower electrode, wrapped this with a tape for isolation, and on one end mounted a screw head as a welding point. The other electrode was freely pressed by hand from above.
Step 7: Triacs an So On
I found an article about how to regulate transformer action on primary side. This was using a triacs similarly as is in a light bulb dimmer or in vacuum cleaners. Lowering power splitting sinusoidal wave. According Fig 11. I collected the necessary components, assembled the circuit, put it in a aluminium box and connected it to the transformer.
Perhaps because of insufficient knowledge, it didn't work as I wanted it to. I could not regulate amps and time duration. I burned out constantly my thin sheets.
Murphy still does not sleep.
Step 8: Conclusion
Let's get serious.
First, learn what the world already tested and wrote. I started with math from the books/web and in a spreadsheet form made a calculator with all the formulas (Proračun transformatora -Transformer calculation) and calculated the dimensions of transformer based on my core. This gave me a figure what my core is capable of. Rewinding the primary and secondary was then necessary.
My frend Mirko Jukl, drew me a simple 555 circuit schematic (Odgoda vremena i trajanje impulsa - Time delay and impulse time) to control time-duration of welding impulse on secondary side. I can choose delay from a few seconds and duration in miliseconds. Small movies show tests with 220V bulb, transformer an when everything was assembled and finished.
And it works!
Because this project was a back and forth process that lasted almost half a year this instructable is a bit inconsistent. Here is the final data of transformer:
Transormer core (E shape) - total square 28 cm2 ... cca 784W.
Primary windings 370 ... for 3,41A ... 1,5 mm dia
Secundar windings 5 ... for 261 A ... 11,54 mm dia
I hope that this DIY project helps somebody to get better results and extend knowledge.
Sincerely...
