Introduction: Kahoot Flooder
This is a fun tool if you need to annoy your teachers at school while you are playing kahoot. It visibly slows down the kahoot when you put more than around 500 bots
Step 1: Materials
You need a pc with node js 14+ installed and a kahoot acount to test
Step 2: Setting Up Package.json
Create a new file called package.json in your bots own directory
copy this code inside it EXACTLY except the title if you want to change that but it cant have spaces
package.json
| "name": "kahoot-bot-by-Jeff", |
| "version": "1.0.0", |
| "description": "", |
| "main": "index.js", |
| "scripts": { |
| "test": "echo \"Error: no test specified\" && exit 1" |
| "keywords": [], |
| "author": "", |
| "license": "ISC", |
| "dependencies": { |
| "an-array-of-english-words": "^2.0.0", |
| "beepbeep": "^1.3.0", |
| "console-title": "^1.1.0", |
| "kahoot.js-updated": "^2.2.6", |
| "random-name": "^0.1.2", |
| "readline-sync": "^1.4.10", |
| "request": "^2.88.2" |
Step 3: Installing Libraries
once you have the package.json set up exactly like that (this step has to be done after the first 2) open a terminal and do npm install. This takes the libraries listed in package.json and installs them.
Step 4: Starting the Code
create a new file in the directory called index.js
you can change this name but if you want it to work you have to edit the entry point in package.json
I will be going over this code later, but if you want to skip right into making the bot work, skip ahead.
gistfile1.txt
| var _0x7007=['console-title','catch','last','TwoFactorCorrect','question','14992ZEODVM','open_ended','questionIndex','type','8097FlppgS','Duplicate\x20name','POSITIVE_INFINITY','QuestionReady','botCount:\x20','t\x20for\x20triangle,\x20d\x20for\x20diamond>\x20','kahoot.js-updated','jumble','10dJxJzf','random','81724YFKzWy','name','t\x20for\x20triangle,\x20d\x20for\x20diamond,\x20c\x20for\x20circle\x20or\x20s\x20for\x20square\x20>\x20','replace','QuizEnd','Created\x20by\x20Jedi\x20Jeff','ceil','clear','first','twoFactorAuth','join','oops\x20messed\x20up','length','quizQuestionAnswers','395816EbaWFZ','setMaxListeners','quiz','leave','answerTwoFactorAuth','Updated\x20version,\x20added\x20random\x20names.','57WkTdgv','Joined','9921rTpKuV','beepbeep','log','survey','answer','SIGINT','all\x20clients\x20joined','request','409189EqwTql','random-name','Kahoot\x20flooder','https://apis.kahoot.it/namerator','95TTXNmw','middle','messed\x20up','QuestionEnd','type\x20your\x20answer>\x20','exit','Flood\x20commencing\x20Wowie','parse','word_cloud','updated\x20version','floor','446203PZQuhU','isCorrect','Disconnect','running','Quiz\x20Locked','t\x20for\x20triangle,\x20d\x20for\x20diamond,\x20c\x20for\x20circle>\x20'];var _0x137e=function(_0xcca91,_0x173849){_0xcca91=_0xcca91-0xa3;var _0x700753=_0x7007[_0xcca91];return _0x700753;};var _0x78553f=_0x137e;(function(_0x4f3ee9,_0x2bb69c){var _0x5bdae8=_0x137e;while(!![]){try{var _0x2ec26d=parseInt(_0x5bdae8(0xdf))+-parseInt(_0x5bdae8(0xbf))*-parseInt(_0x5bdae8(0xd7))+-parseInt(_0x5bdae8(0xc1))+parseInt(_0x5bdae8(0xa8))+parseInt(_0x5bdae8(0xd5))*parseInt(_0x5bdae8(0xb7))+parseInt(_0x5bdae8(0xcf))+parseInt(_0x5bdae8(0xb3))*-parseInt(_0x5bdae8(0xe3));if(_0x2ec26d===_0x2bb69c)break;else _0x4f3ee9['push'](_0x4f3ee9['shift']());}catch(_0x3f8564){_0x4f3ee9['push'](_0x4f3ee9['shift']());}}}(_0x7007,0x4ab3f),console[_0x78553f(0xd9)](_0x78553f(0xab)),console[_0x78553f(0xd9)](_0x78553f(0xa6)),readline=require('readline-sync'));const Kahoot=require(_0x78553f(0xbd));var words=require('an-array-of-english-words');const request=require(_0x78553f(0xde));var random=require(_0x78553f(0xe0)),setTitle=require(_0x78553f(0xae));setTitle(_0x78553f(0xe1));var beep=require(_0x78553f(0xd8));function getRandomInt(_0x227c08,_0x1b4b38){var _0x1a4b88=_0x78553f;return _0x227c08=Math[_0x1a4b88(0xc7)](_0x227c08),_0x1b4b38=Math[_0x1a4b88(0xa7)](_0x1b4b38),Math[_0x1a4b88(0xa7)](Math[_0x1a4b88(0xc0)]()*(_0x1b4b38-_0x227c08+0x1))+_0x227c08;}function getName(){var _0x5014e7=_0x78553f;ran=getRandomInt(0x1,0x5);ran==0x5&&request(_0x5014e7(0xe2),function(_0x5273f6,_0x20bddb,_0x527d93){var _0xdecf49=_0x5014e7;return _0x5273f6&&console['log'](_0x5273f6),JSON[_0xdecf49(0xa4)](_0x527d93)[_0xdecf49(0xc2)];});if(ran==0x4)return words[getRandomInt(0x1,words[_0x5014e7(0xcd)])];if(ran==0x3)return random[_0x5014e7(0xc9)]();if(ran==0x2)return random[_0x5014e7(0xc9)]()+random[_0x5014e7(0xe4)]()+random[_0x5014e7(0xb0)]();if(ran==0x1)return random[_0x5014e7(0xc9)]()+random[_0x5014e7(0xb0)]();}function shuffle(_0x49c610){var _0x1dc814=_0x78553f,_0x17fcbb=_0x49c610['length'],_0x3d207b,_0x57f6e6;while(0x0!==_0x17fcbb){_0x57f6e6=Math[_0x1dc814(0xa7)](Math[_0x1dc814(0xc0)]()*_0x17fcbb),_0x17fcbb-=0x1,_0x3d207b=_0x49c610[_0x17fcbb],_0x49c610[_0x17fcbb]=_0x49c610[_0x57f6e6],_0x49c610[_0x57f6e6]=_0x3d207b;}return _0x49c610;}process['setMaxListeners'](Number[_0x78553f(0xb9)]),console[_0x78553f(0xc8)](),console[_0x78553f(0xd9)](_0x78553f(0xc6)),console[_0x78553f(0xd9)](_0x78553f(0xd4)),readline[_0x78553f(0xb2)]('Press\x20enter\x20to\x20continue'),antibotmode=readline[_0x78553f(0xb2)]('random\x20Name(y/n):\x20'),pin=readline[_0x78553f(0xb2)]('Pin:\x20'),bots=readline['question'](_0x78553f(0xbb));antibotmode=='y'?(ranname=!![],er='n'):(ranname='n',ranname=='y'?ranname=!![]:(ranname=![],botname=readline['question']('Name:\x20'),botprefix=''),er='n');usercontrolled='n';usercontrolled=='y'?(usercontrolled=!![],beepis='y'):(usercontrolled=![],beepis='n');console[_0x78553f(0xc8)](),repeattimes=0x0;function sendjoin(_0x5a9eb1,_0x426054){ranname?join(getName(),_0x426054):join(_0x5a9eb1,_0x426054);}function spam(){var _0x3e0759=_0x78553f;repeattimes==bots?console[_0x3e0759(0xd9)](_0x3e0759(0xdd)):(repeattimes++,ranname?rt=getRandomInt(0x5a,0xc8):rt=0xf,setTimeout(()=>{spam();},rt),setTimeout(()=>{ranname?sendjoin('This\x20will\x20become\x20a\x20random\x20name!',bots-repeattimes-0x1):sendjoin(botname+(bots-repeattimes-0x1),bots-repeattimes-0x1);},rt));}process[_0x78553f(0xd0)](Number['POSITIVE_INFINITY']),Arandomint=0x0,todo=![];function join(_0x57aba3,_0x1e9a42){var _0x92146b=_0x78553f;while(_0x57aba3==undefined){_0x57aba3=getName();}const _0x39e1f6=new Kahoot();_0x39e1f6[_0x92146b(0xd0)](Number['POSITIVE_INFINITY']);er=='y'?_0x39e1f6[_0x92146b(0xcb)](pin,_0x57aba3['replace'](/a/g,'ᗩ')[_0x92146b(0xc4)](/b/g,'ᗷ')[_0x92146b(0xc4)](/c/g,'ᑕ')[_0x92146b(0xc4)](/d/g,'ᗪ')[_0x92146b(0xc4)](/e/g,'E')[_0x92146b(0xc4)](/f/g,'ᖴ')['replace'](/g/g,'G')[_0x92146b(0xc4)](/h/g,'ᕼ')[_0x92146b(0xc4)](/i/g,'I')[_0x92146b(0xc4)](/j/g,'ᒍ')['replace'](/k/g,'K')['replace'](/l/g,'ᒪ')['replace'](/m/g,'ᗰ')[_0x92146b(0xc4)](/n/g,'ᑎ')[_0x92146b(0xc4)](/o/g,'O')[_0x92146b(0xc4)](/p/g,'ᑭ')['replace'](/q/g,'ᑫ')[_0x92146b(0xc4)](/r/g,'ᖇ')[_0x92146b(0xc4)](/s/g,'ᔕ')[_0x92146b(0xc4)](/t/g,'T')[_0x92146b(0xc4)](/u/g,'ᑌ')['replace'](/v/g,'ᐯ')[_0x92146b(0xc4)](/w/g,'ᗯ')[_0x92146b(0xc4)](/x/g,'᙭')[_0x92146b(0xc4)](/y/g,'Y')['replace'](/z/g,'ᘔ')['replace'](/A/g,'ᗩ')[_0x92146b(0xc4)](/B/g,'ᗷ')[_0x92146b(0xc4)](/C/g,'ᑕ')[_0x92146b(0xc4)](/D/g,'ᗪ')[_0x92146b(0xc4)](/E/g,'E')[_0x92146b(0xc4)](/F/g,'ᖴ')['replace'](/G/g,'G')[_0x92146b(0xc4)](/H/g,'ᕼ')[_0x92146b(0xc4)](/I/g,'I')[_0x92146b(0xc4)](/J/g,'ᒍ')[_0x92146b(0xc4)](/K/g,'K')[_0x92146b(0xc4)](/L/g,'ᒪ')[_0x92146b(0xc4)](/M/g,'ᗰ')[_0x92146b(0xc4)](/N/g,'ᑎ')[_0x92146b(0xc4)](/O/g,'O')['replace'](/P/g,'ᑭ')[_0x92146b(0xc4)](/Q/g,'ᑫ')[_0x92146b(0xc4)](/R/g,'ᖇ')[_0x92146b(0xc4)](/S/g,'ᔕ')[_0x92146b(0xc4)](/T/g,'T')['replace'](/U/g,'ᑌ')[_0x92146b(0xc4)](/V/g,'ᐯ')['replace'](/W/g,'ᗯ')[_0x92146b(0xc4)](/X/g,'᙭')[_0x92146b(0xc4)](/Y/g,'Y')[_0x92146b(0xc4)](/Z/g,'ᘔ'),[random[_0x92146b(0xc9)](),random[_0x92146b(0xb0)]()])[_0x92146b(0xaf)](_0x3aee8a=>{var _0x3c0b2a=_0x92146b;_0x3aee8a['description']==_0x3c0b2a(0xb8)&ranname?sendjoin(_0x57aba3,_0x1e9a42):(console[_0x3c0b2a(0xd9)](_0x3c0b2a(0xcc)),_0x39e1f6[_0x3c0b2a(0xd2)]());}):_0x39e1f6['join'](pin,_0x57aba3,[random[_0x92146b(0xc9)](),random[_0x92146b(0xb0)]()])[_0x92146b(0xaf)](_0xd64c85=>{var _0x17ac03=_0x92146b;_0xd64c85['description']=='Duplicate\x20name'&ranname?sendjoin(_0x57aba3,_0x1e9a42):(console[_0x17ac03(0xd9)](_0x17ac03(0xe5)),_0x39e1f6[_0x17ac03(0xd2)]());});var _0x425dc1=[0x0,0x1,0x2,0x3];todo=![],_0x39e1f6['on'](_0x92146b(0xd6),_0x3617cc=>{var _0x4f6a81=_0x92146b;_0x3617cc[_0x4f6a81(0xca)]&&setInterval(()=>{var _0xbae7a4=_0x4f6a81;!todo==![]&&_0x39e1f6[_0xbae7a4(0xd3)](todo),shuffle(_0x425dc1),_0x39e1f6[_0xbae7a4(0xd3)](_0x425dc1);},0x3e8);}),_0x39e1f6['on'](_0x92146b(0xb1),function(){var _0x22828c=_0x92146b;console[_0x22828c(0xd9)](''),todo=_0x425dc1;}),_0x39e1f6['on'](_0x92146b(0xba),_0x440b91=>{var _0x4ab7e7=_0x92146b;_0x1e9a42==0x1&beepis=='y'&&beep();everyoneanswerthis=![];if(_0x440b91[_0x4ab7e7(0xb6)]==_0x4ab7e7(0xa5)){if(usercontrolled){if(_0x1e9a42==0x1)everyoneanswerthis=!![],answer=readline[_0x4ab7e7(0xb2)]('type\x20your\x20answer>\x20'),everyoneanswerthis=answer,Arandomint=answer,setTimeout(()=>{_0x39e1f6['answer'](answer-0x1);},getRandomInt(0x1,0x4e20));else var _0x17dc9f=setInterval(()=>{(!everyoneanswerthis==![]||!everyoneanswerthis==!![])&&(clearInterval(_0x17dc9f),setTimeout(()=>{var _0xce9e0c=_0x137e;_0x39e1f6[_0xce9e0c(0xdb)](Arandomint);},getRandomInt(0x1,0x4e20)));},0x64);}else console[_0x4ab7e7(0xd9)](''),setTimeout(()=>{var _0xddbe0f=_0x4ab7e7;_0x39e1f6[_0xddbe0f(0xdb)]('f');},getRandomInt(0x1,0x4e20));}_0x440b91['type']==_0x4ab7e7(0xbe)&&(console[_0x4ab7e7(0xd9)](''),setTimeout(()=>{var _0x4a0da3=_0x4ab7e7;_0x39e1f6[_0x4a0da3(0xdb)](getRandomInt(0x0,_0x440b91[_0x4a0da3(0xce)][_0x440b91[_0x4a0da3(0xb5)]]-0x1));},getRandomInt(0x1,0x4e20)));if(_0x440b91[_0x4ab7e7(0xb6)]==_0x4ab7e7(0xd1)){if(usercontrolled){if(_0x440b91[_0x4ab7e7(0xce)][_0x440b91[_0x4ab7e7(0xb5)]]==0x2){if(_0x1e9a42==0x1)everyoneanswerthis=!![],answer=readline[_0x4ab7e7(0xb2)](_0x4ab7e7(0xbc)),answer=answer[_0x4ab7e7(0xc4)]('t',0x1)['replace']('d',0x2),everyoneanswerthis=answer,Arandomint=answer,setTimeout(()=>{var _0x46755d=_0x4ab7e7;_0x39e1f6[_0x46755d(0xdb)](answer-0x1);},getRandomInt(0x1,0x4e20));else var _0x17dc9f=setInterval(()=>{(!everyoneanswerthis==![]||!everyoneanswerthis==!![])&&(clearInterval(_0x17dc9f),setTimeout(()=>{_0x39e1f6['answer'](Arandomint-0x1);},getRandomInt(0x1,0x4e20)));},0x64);}if(_0x440b91['quizQuestionAnswers'][_0x440b91[_0x4ab7e7(0xb5)]]==0x3){if(_0x1e9a42==0x1)everyoneanswerthis=!![],answer=readline[_0x4ab7e7(0xb2)](_0x4ab7e7(0xad)),answer=answer[_0x4ab7e7(0xc4)]('t',0x1)[_0x4ab7e7(0xc4)]('d',0x2)[_0x4ab7e7(0xc4)]('c',0x3),everyoneanswerthis=answer,Arandomint=answer,setTimeout(()=>{_0x39e1f6['answer'](answer-0x1);},getRandomInt(0x1,0x4e20));else var _0x17dc9f=setInterval(()=>{(!everyoneanswerthis==![]||!everyoneanswerthis==!![])&&(clearInterval(_0x17dc9f),setTimeout(()=>{_0x39e1f6['answer'](Arandomint-0x1);},getRandomInt(0x1,0x4e20)));},0x64);}if(_0x440b91[_0x4ab7e7(0xce)][_0x440b91[_0x4ab7e7(0xb5)]]==0x4){if(_0x1e9a42==0x1)everyoneanswerthis=!![],answer=readline[_0x4ab7e7(0xb2)](_0x4ab7e7(0xc3)),answer=answer[_0x4ab7e7(0xc4)]('t',0x1)[_0x4ab7e7(0xc4)]('d',0x2)[_0x4ab7e7(0xc4)]('c',0x3)[_0x4ab7e7(0xc4)]('s',0x4),everyoneanswerthis=answer,Arandomint=answer,setTimeout(()=>{var _0x3923e3=_0x4ab7e7;_0x39e1f6[_0x3923e3(0xdb)](answer-0x1);},getRandomInt(0x1,0x4e20));else var _0x17dc9f=setInterval(()=>{(!everyoneanswerthis==![]||!everyoneanswerthis==!![])&&(clearInterval(_0x17dc9f),setTimeout(()=>{_0x39e1f6['answer'](Arandomint-0x1);},getRandomInt(0x1,0x4e20)));},0x64);}}else setTimeout(()=>{var _0x4e737d=_0x4ab7e7;toanswer=getRandomInt(0x0,_0x440b91[_0x4e737d(0xce)][_0x440b91[_0x4e737d(0xb5)]]-0x1),console['log'](''),_0x39e1f6[_0x4e737d(0xdb)](toanswer);},getRandomInt(0x1,0x4e20));}if(_0x440b91[_0x4ab7e7(0xb6)]==_0x4ab7e7(0xda)){if(usercontrolled){if(_0x1e9a42==0x1)everyoneanswerthis=!![],answer=readline['question']('t\x20for\x20triangle,\x20d\x20for\x20diamond,\x20c\x20for\x20circle\x20or\x20s\x20for\x20square\x20>\x20'),answer=answer[_0x4ab7e7(0xc4)]('t',0x1)[_0x4ab7e7(0xc4)]('d',0x2)['replace']('c',0x3)[_0x4ab7e7(0xc4)]('s',0x4),everyoneanswerthis=answer,Arandomint=answer,setTimeout(()=>{_0x39e1f6['answer'](answer-0x1);},getRandomInt(0x1,0x4e20));else var _0x17dc9f=setInterval(()=>{(!everyoneanswerthis==![]||!everyoneanswerthis==!![])&&(clearInterval(_0x17dc9f),setTimeout(()=>{var _0x1fc75c=_0x137e;_0x39e1f6[_0x1fc75c(0xdb)](Arandomint-0x1);},getRandomInt(0x1,0x4e20)));},0x64);}else setTimeout(()=>{var _0x4f54f4=_0x4ab7e7;toanswer=getRandomInt(0x0,_0x440b91[_0x4f54f4(0xce)][_0x440b91[_0x4f54f4(0xb5)]]-0x1),console['log'](''),_0x39e1f6[_0x4f54f4(0xdb)](toanswer);},getRandomInt(0x1,0x4e20));}if(_0x440b91[_0x4ab7e7(0xb6)]==_0x4ab7e7(0xb4)){if(usercontrolled){if(_0x1e9a42==0x1)everyoneanswerthis=!![],answer=readline['question'](_0x4ab7e7(0xe7)),everyoneanswerthis=answer,Arandomint=answer,setTimeout(()=>{_0x39e1f6['answer'](answer-0x1);},getRandomInt(0x1,0x4e20));else var _0x17dc9f=setInterval(()=>{(!everyoneanswerthis==![]||!everyoneanswerthis==!![])&&(clearInterval(_0x17dc9f),setTimeout(()=>{var _0x97aa8a=_0x137e;_0x39e1f6[_0x97aa8a(0xdb)](Arandomint);},getRandomInt(0x1,0x4e20)));},0x64);}else console[_0x4ab7e7(0xd9)](''),setTimeout(()=>{_0x39e1f6['answer']('x');},getRandomInt(0x1,0x4e20));}}),_0x39e1f6['on'](_0x92146b(0xaa),_0x5d4fa5=>{var _0x34cd3c=_0x92146b;!_0x5d4fa5==_0x34cd3c(0xac)&&sendjoin(_0x57aba3,_0x1e9a42);}),_0x39e1f6['on'](_0x92146b(0xe6),_0x53632d=>{var _0x493666=_0x92146b;_0x53632d[_0x493666(0xa9)]?console[_0x493666(0xd9)](''):console[_0x493666(0xd9)]('');}),_0x39e1f6['on'](_0x92146b(0xc5),_0x1f1aac=>{var _0x6c56a2=_0x92146b;console[_0x6c56a2(0xd9)]('');}),process['on'](_0x92146b(0xdc),function(){var _0x4b5ee8=_0x92146b;process[_0x4b5ee8(0xe8)]();});}console[_0x78553f(0xc8)](),console[_0x78553f(0xd9)](_0x78553f(0xa3)),spam(); |
Step 5: Going Over the Code
This code basically calls the libraries for input and then picks a random word and connects to kahoot
thats it
Step 6: Running the Code
To test the bot open a terminal and do
node index.js
and start a kahoot and follow the instructions in the terminal
