Introduction: Armed Costume Hallowen Dios Indu India Kali Costume 4 Arms Disfraz Kali 4 Brazos TENERIFE CARNAVAL ORIGINAL DISFRAZ Goddes
Step 1: Making Arms/ Haciendo Brazos
Polyurethane foam, 4 bottles and two gloves create the arms of the goddess Kali. You only have to fill both gloves as bottles and let it dry. When dry, cut off the plastic bottle and removing the foam cylinder is formed. We will join two cylinders and two cylinders to form two joint arms in your medium. Likewise, with masking tape will join hands with the distal part of the arms. With a cardboard lid, shoe box, we will set the basis for arms following the same technique the foam will fill you with more consistency. When dry drilling anchor arms to the base and reinforce with masking tape the entire structure. To finish I will post some eslastico to set us back arms
Con espuma de poliuretano, 4 botellas y dos guantes crearemos los brazos de la diosa kali. Para ello solo tenemos que rellenar tanto los guantes como las botellas y dejarlo secar. Cuando este seco, cortaremos el plastico e la botella sacando el cilindro de espuma que se ha formado. Uniremos dos cilindros y dos cilindros para formar dos brazos con su articulacion en medio. Asi mismo, uniremos con cinta de carrocero las manos a la parte distal de los brazos. Con una tapa de carton, tipo caja de zapatos, haremos la base para fijar los brazos siguiendo la misma tecnica la rellenaremos de espuma para darle mas consistencia. Cuando haya secado anclaremos perforando los brazos a la base y reforzaremos con cinta de carrocero toda la estructura. Para terminar le colocaremos unos eslastico para fijarnos los brazos a la espalda
Step 2: Making the Accesories
With cardboard become part of the accessories. In this case the crown patterns Kali.Dibujaremos one crown and earrings, which subsequently forraremos with gold cloth and decorate with colored Pieras, for this we will use a hot glue gun. We will place an elastic to secure it to the contour of the head
Con carton hacemos parte de los accesorios. En este caso la corona de Kali.Dibujaremos un patro de corona y pendientes, el cual posteriormente forraremos con tela dorada y decoraremos con pieras de colores, para ello vamos a usar una pistola de cola termofusible. Le colocaremos un elastico para fijarlo al contorno de la cabeza
Step 3: The Result
Let's do a loincloth something macabre. We will use shaped golden fabric belt and a riangulo of Lantero and rear. Decorating the sides with red blood stained gloves.
Vamos a hacer un taparrabos algo macabro. Para ello usaremos tela dorada con forma de cinturon y un riangulo de lantero y otro trasero. Decorando los laterales con guantes teñidos de rojo sangre.
