Introduction: Keepin' It Cool
For those of you who weld, do you ever get over heated? Would you not want a helmet that could cool you down? This helmet is programmed to use a simple fan from radioshack and a temperature sensor from parallax to cool you down. The fan kicks on by itself to blow a cool breeze.
Step 1: Gather Materials
For the helmet you will need:
- 2 9v Batteries
- 1 9V snap connecter
- 1 12VDC Brushless Fan
- 2 220 ohms risitors
- Screw Driver Phillips head
- 8 Screws (23.73mm)L (2.71mm)W
- 8 nuts (6.24mm)
- 5 foot of 22 gage wire (60 inches)
- Paralax LM34 Temperature Sensor
- Paralax bread Board with minicontroller
- Paralax Basic Stamp program installed on computer
- Wielding Helment
- An Analog to digital transfer
- Power Drill
- 3/32 Drill bit
- 1 self leading wood drill bit 2â = 54mm
- Velcro
- Solder gun
- Solder wire
- 1 Roll of electrical tape
- Parallax Analog to Digital converter
- 2 9v Batteries
- 8 nuts (6.24mm)
- Wielding Helment
- Power Drill
- 3/32 Drill bit
- Velcro
- Solder gun
- Solder wire
Step 2: Order Parts
- Visit parallax.com, search for LM34 Temperature Sensor
- Buy a 3 inch 12VDC Cooling Fan from Radio Shack
- Parts may take a week to come in.
Step 3: Download Basic Stamp Software
- Download the basic stamp software on to your computer
- It can be found at http://www.parallax.com/tabid/441/Default.aspx
- Download software according to which Operating system you have on your computer.
Step 4: Drill Holes
- On the Front of helmet, Drill holes according to fan. The fan will have pre-drilled holes for mounting. Use the 3/32 drill bit to drill
- Also cut a vent hole with a 2â self leading bit, for fan to get circulation.
Step 5: Mount Fan
- Take screws, mount fan on inside of helmet so the fan can blow on your face.
- Once screws are in, secure the screw with a nut, so they remain in place.
Step 6: Cut Holes for Board
- Cut holes in one side of you helmet to keep your board in place.
- Cut the holes according the size of your board
Step 7: Solder Wire to Temperature Sensor/9v Snap Connecter
- Solder 1 foot of 22 gage wire to each prong on the LM34 temperature sensor
- Then solder the wires of the snap connecter to a foot of 22 gage wire
- Wrap the connection with electrical tape
Step 8: Mount Bread Board
- Take screws, mount the board on inside of helmet on the left side.
Step 9: Wire Up Everything
- To wire everything together, use the following pg. 183 PDF file:
http://www.scribd.com/doc/35753337/44/ACTIVITY-1-TESTING-THE-LM34
-The PDF file will give you a diagram of the wiring needed for the use of the analog to digital transfer.
Step 10: Plug in Sensor
-Plug senors supply into the VDD slot
-Plug the ground into VSS
-Plug the output into pin8
-For further help us the PDF file http://www.scribd.com/doc/35753337/44/ACTIVITY-1-TESTING-THE-LM34 use the diagram of the senor at the top of page 183 to help
Step 11: Plug in Code
' {$STAMP BS2}
' {$PBASIC 2.5}
DigDataIn VAR Bit
ADC_DataIn VAR Byte
temp CON 255
LED PIN 0
DigIn PIN 8
ADC_CS PIN 13
ADC_Clk PIN 14
ADC_Dout PIN 15
OUTPUT LED
PAUSE 1000
DO
GOSUB ReadData
GOSUB PlotData
PAUSE 20
GOSUB run
PAUSE 500
LOOP
ReadData:
LOW ADC_CS
DigDataIn = DigIn
SHIFTIN ADC_Dout, ADC_Clk, MSBPOST, [ADC_DataIn\9]
HIGH ADC_CS
RETURN
PlotData:
DEBUG IBIN DigDataIn, CR
DEBUG "[", DEC ADC_DataIn, ",*,.0196]",CR
RETURN
run:
IF (DigDataIn > temp) THEN
HIGH 0
PAUSE 20
ENDIF
RETURN
Step 12: Secure Wiring
- Tape or glue all wires to the inside of the helmet so that nothing disrupts your vision.
Step 13: Stay Cool :)
-Have fun, be safe, and stay COOL :)
