Introduction: Kendama Body (Ken)
A kendama body (without ball) because I enjoy kendama.
  • Wood Lathe
  • Wood Glue
  • Wood Finish
  • Drill
  • Lathe Tools (Live end, cylindrical end chisel tool, wood chuck)
  • Pine and Maple wood (dimensions vary based on what you have due to gluing)
  • Miter Saw
  • Band Saw
  • Sand Paper
Step 1: Large Part of Kendama Body
  • I used 2x4 pine scrap pieces of wood.
  • Cut your wood into three 7.5 inch long pieces using a miter saw.
Step 2: First Glue
  • Glue the three pieces together keeping them as straight as possible.
  • I used a vice for this step.
Step 3: Mark Center and Cups Then Bandsaw to Cylindrical Shape
  • Mark the center of the wood block after gluing..
  • Do this by using a ruler and a pencil and tracing along the corners.
  • Use a bandsaw to take the corners off each side to make the block turn better on the lathe.
Step 4: Wood Lathe First Piece
  • Using the wood chuck, begin to turn the base cup.
  • It does not need to be to deep, I went about have an inch in diameter.
Step 5: Wood Lathe First Piece Pt 2
  • After turning out the base cup, move the block into a live end so you can turn the wood.
  • Turn the wood into a cone shape that is thinnest, and farthest from the base cup.
  • Make sure not to go to thin and break the block.
  • Add interesting ribs and lines.
  • Once the shape you want is acquired, take the block off the chuck and use a chisel to press off the excess wood on the end of the thin end.
  • Sand the thin end to remove harsh edge.
Step 6: Second Glue
  • I used maple 2x4s scrap wood for this step.
  • Cut the wood to roughly 3.5 inches.
  • Keep the wood straight and glue them together with a vice or clamp.
Step 7: Mark Center and Cups Then Bandsaw to Cylindrical Shape
  • Mark the center of the wood and the diameter of the big and little cups.
  • The big cup should be about 1.3 inches (measured with caliper) in diameter and the little cup would be about 1 inch in diameter.
  • Take the block to the band saw and take of the corners until the block is more cylindrical.
Step 8: Woodlathe Second Piece
  • Put the wood block in the chuck and turn out the smaller cup.
  • Put the wood block on the other side of the chuck and turn out the big cup.
  • Turn the wood down in the middle to a parabular shape.
Step 9: Create Taper Hole
On the second piece there needs to be a tapered hole so it can slide onto the cone shaped first piece.
To do this,
  • You can Use a drill to create a hole then a cylindrical wood file to taper the hold at the bottom.
  • Or, use a taper drill bit, but I did not have access to a tapered drill bit.
Step 10: Sand and Finish
  • Sand the wood. I used 150 grit to maintain some of the grit of the wood so it could catch the ball better.
  • Finish with wood stain.
Step 11: Glue Together (Optional)
  • Glue the pieces together if desired.
  • This step is preference based.
