Introduction: Kenx Double Barrel Gun.
Hey guys, I've been working on this, it is a double barrel pirate gun. It is a simple type of gun. Sadly, I did not make a trigger, it would have been to big. Enjoy!
Here are the supplies. Like I said, it is not many, just a lot of those single gray clips.
Step 1: The Handle.
The handle: Make the two parts in the second image and then put them together like in the third image. Repeat this in sets of two, four more times and then put one gray clip on the end of both rods.
Step 2: The Trigger.
Make what is in the first image, then add the orange part on the white rod. Then take the second red connector and clip it on like so.
Step 3: The Barrel.
Make what is in the first image the same way as the handle. Then add the four clips like so. Then add the part in the back. Next up, grab those triggers you made and clip them on like so. then fill in the gap with gray clips. Then make what is in image eight and add it to the back. Make two of these rods with a clip on the end and push them down the barrel. For the bands, make a loop on the top of the red rod. Then pull it back and put it on the end of the yellow rod. Take the top part of the band and put it in the middle of the barrel and put the bottom under the barrel.
Step 4: Assembly.
Snap the two parts together like so.
Step 5: How to Fire.
First pull back both yellow rods and push down the orange part in front of the rod to hold the rod back. Then put a white or green rod down the barrels. Then hold the gun like so, and push down the white rod on the end of the orange part and let it fly. Have fun!
