Introduction: Ketchup USB
The great thing about USB thumb drives is their regular form factor and the small size of their "innards". This gives a great opportunity for customising! This instructible is more for inspiration that technical instructions.
This USB drive has had a number of "bodies", but this is my favourite so far. Most people that have seen it have asked about it. Most ask if the ketchup affects the electronics! Now, see how it is done.
Caveat. This is a real ketchup packet that contains ketchup. Squeeze too hard and it might burst. Also the life of the packet is about 2-3 months of use as a USB cover. After that it gets too soft and starts delaminating. Do not use this USB drive cover for mission critical data. You have been warned!
What you need:
USB drive (without it's outer casing)
2 Ketchup packets (one that are not filled too much are better)
Double-sided sticky tape
Scissors
PS Sorry for the bad pictures, I used my phone camera!
What you need:
Scissors
Step 1: How to Make It!
Although most people think the USB drive is in the packet, it actually sits on top!
1) Cut open one ketchup packet. Use the ketchup on your chips (don't waste it!). Cut out the coloured part along the edge. The edge will help to hide the seams. Clean the inside of the cover.
2) Cover your USB drive with tape to protect it. Then use double sided sticky tape to tape the drive to the cover of the the second packet.
3) Cover the back of the cover with double sided tape making sure to cover the edges, but not let the tape show.
4) Tape the cover carefully on the second packet lining up the edges and making sure the edges are firmly stuck done. This will make it almost invisible.
5) Make up a story on how you managed to mix ketchup and (micro)chips to tell your amazed friends!
Now go and use your imagination to create your own USB cover. And don't forget to show us what you have come up with!
