Introduction: Keyholder/mail Holder
This project, made completely out of 2x4s can be made by anyone with basic woodworking experience.
Step 1: Assembling the Panelboard
First, I took a 2x4 and set the blade on the table saw a little past halfway up the middle of the 2x4, not cutting through it all at once, i then flipped it over and cut the other side making 1x4s. I repeated this process a couple more times. Using wood glue i glued them together and used a clamp to make sure there is no gaps in between the 1x4s.
Step 2: Cutting the “pie” Peices
Once you have made the cut, simply flip the board over, set the miter angle at 0 like shown in the picture and you will have another pie peice!
Step 3: Cutting the Side Block Peices
Step 4: Assembling the Basket and Shelf
For assembling the basket, i put the pie pieces 9 inches up from the bottom of the backboard. i put the side block pieces right on top of the pie pieces and wood glued them together. please wait 24 hours for it to be done.After that put the two pieces of 2x4 you cut in half and put it across and wood glue those. make sure to clamp these down to ensure it does glue the whole thing
Step 5: Sanding
starting with 60 grit, sand everything from front to back to get rid of any bumps/ irregular marks. then moving up to 150 grit start smoothing it out, go up to 220 grit and work up to how smooth you want it.
Step 6: Torching
Step 7: Adding the Hooks
for these hooks, i spaced them in between where the 1x4 back board breaks in between, you can add more hooks to put more stuff on the back board just make sure they are evenly spaced out and then your'e finished!
