Introduction: Awesome Looking FAN HEATER Cover Up for Under5$ OMG
Thanks everyone.
Step 1: Getting Started:Materials
:Ceramic bowl-BIG BIG one
:Sheet of wood or sheet of metalmake sure its easy to cut i chose this cardboard like wood nice and floppy wood was'nt a good idea because it might go on fire so try to use metal.
:Plastic or metal pipes.
:Measuring tape, drill, saw, ruler,clamp,screw driver and pencil
:Delta sander if you have one or sand paper
:Screws and nuts & bolts
:Plank of wood doesnt have to be new try looking in a skip or something make sure its bigger then ceramic bowl
:6 small L shape brakets
NOW WE ARE READY TO ROCK & ROLL
Step 2: Find Suitable Place
Hover your mouse over the image
Step 3:
Lets get started with your sheet of metal
Cut your material according to the dimensions given on the picture.
Step 4: Dimensions
Step 5: More Dimensions
Step 6: And Even More Dimensions
Step 7: Wall Framing
Step 8: Sides
Get your 11.25cm by 22cm sheet of material that you cutted out in step 4 and screw it on either side of the beam it should fit perfectly covering the whole beam.
Step 9: Instaling the Front Part 1
Step 10: Installin the Front Part 2
Step 11: Sides
Step 12: More Sides
Step 13: Front
Step 14: Front Part 2
Step 15: Lid
On the left hand side do the same as you did in step 11 & 12.
On the top fit rectangle piece of material 11.25cm by 22cm then secure with 4 screws.
Step 16: Secure
Step 17: Seal
After the sealent has dried use your sand paper or delta sander to sand down the edges.
Step 18: Pipes
First you drill three large holes on the top and do the same with the pipe cut your pipe the correct size that fits you the best then connect the pipe to the chimney or escape but don't forget to drill the hole in the chimney. The pipes are held down onto the fire place by ''no more nails'' well you can use an other sealent or bolts if you want to. The pipe was connected to the chimney in the same way. But don't forget to seal of one end of the pipe or else the smoke will start escaping through there.
Step 19: Multifunction
Spray your fire place top or paint it with whatever colour you like i used silver.
Well those who are wondering how it can be used as a cover for a fan heater. This is how. You do all the previous steps except the pipe connecting ones. Get your fan heater place it inside the ceramic bowl then make a sort of tripod over it with sticks then place a weak light bulb inside the tripod along with the fan heater.
Outdoor fire & barbeque: get the ceramic bowl set your fire inside. Then roast your food over it. The reason I chose a ceramic bowl was because its easily washable and does not look ugly and can be brought back into the house to be used as a firplace again.
You can boil your water on top of the fireplace by using a sheet of metal then cuting
4 , 6 , 8 , 10 , 12 square holes into the metal you will then be suprised by the effect of the fire [ It looks really cool ]. Now you can also boil water and cook food.
Step 20: The End
Thanks everone for looking at my first instructable please rate, subscribe and give me some feed back, so it might encourage me to write a make an other one.
Any accidents and damage caused by this instructable
I am not liable.
I will soon published a new instructable on how to make Banksy templates even the coloured ones. Also how to make your own
