Introduction: Kids Night Light
About: I love making stuff, I love Instructables, I love tools, I love machines, and I love materials. But most of all I love Arnie.
Easy make, kid friendly night light, this gives the kiddies independence of turning the light on or off on their own and has a fun appearance. The best bit of the design is the lack of a traditional on/off switch as it is operated by a magnetic reed switch, see the video below.
Cost:
Magnet = £2.50 each set (I used alarm contacts)
Duck = £1.25 each (ebay)
LED's = 4p each (ebay)
Base = free (ofcuts and treasure found in garage)
Step 1: Magnet in Duck
  • Drill a hole the same diameter as the magnetic contact mine required Ø15mm. Place it in the middle of the bottom of the duck. I used a hole saw in a cordless drill.
  • You must ensure you use the contact without the wires on.
  • The magnet is held in by friction, however if you want a more permanent fixing use hot glue
Step 2: Base - Cutting the Squares
  • Cut MDF into 120 x 120mm squares
  • The number of squares depends on the thickness of mdf used and how high you want the pillars
  • I used 22mm thick MDF is it means less cutting and glueing of layers
Step 3: Base - Marking Out
  • On three squares use a ruler to cross the corners to find the centre
  • Use a compass to create a Ø120mm circle on the three squares
  • Put these three squares to one side as they will become the top of the pillars later on.
Step 4: Base - Cutting the Holes
  • Cross the corners to find the centre.
  • Using an adjustable hole saw / Fly cutter create a Ø100mm hole in all the layers of MDF
  • I used a hand drill, however i would recommend using a pillar drill set to a slow speed as its a bit safer.
  • If you do not have the above tools you could use a coping saw or electric jigsaw to create the holes
Step 5: Base - Glue
  • Using PVA wood glue stic the layers together until you reach the desired height
  • You must ensure that the holes are aligned and not the outside edges
  • Stick the top layer on that you marked out earlier
Step 6: Base - Bottom Plate
  • Cut three pieces of 4mm MDF to 120 x 120mm
  • Using a compass create two circles at Ø100mm and Ø120mm
  • Mark three positions of the screws in the layout shown in the photo, the hole positions are a-symmetrical so the bottom plate is easy to re-align when removed
  • Drill and countersink the holes to take a standard CSK wood screw (approx 4x20mm)
Step 7: Base - Attaching the Bottom Plate
  • Align the bottom plate onto the stack and drill the pilot holes for the screws
  • Screw on the plate
Step 8: Base - Making It Round
  • Use a band saw to cut as much material away as possible
  • If you do not have access to a band saw you could use a hand saw
Step 9: Base - Making It Round
  • Use a disk or belt sander to sand the MDF to the circle you drew earlier
  • This could be done by hand with abrasive paper but it will take a very long time
Step 10: Base - Making It Round
  • Use a table router to either add a chamfer or radius to the top edge
  • If you do not have this equipment use abrasive paper to round off the edge
Step 11: Base - Marking LED Holes
  • Use the base of the duck to set the diameter of the compass
  • Use the centre you marked out earlier and draw a circle
  • Where the circle intersects the four lines, it creates the drill position for the LED holes
Step 12: Base - Drilling the Holes
  • Use a Ø15mm drill bit or a hole saw to create the hole in the middle
  • Use a Ø6mm drill to create the LED holes
Step 13: Circuit - Soldering
  • See the circuit diagram for component & wiring positions
  • Solder all the wires onto the components and test with a battery and the other half of the magnetic switch
  • I used
    • white super bright LEDs 5mm
    • Magnetic alarm contact
    • 9v battery clip
    • 9v PP3 battery
    • 360Ω resistor
Step 14: Circuit - Insulating
  • Remove the circuit and cover all exposed metal with insulation tape, retest the circuit to ensure it still works
  • Reinsert the circuit and glue gun the back of the LED's
  • Screw the bottom on
Step 15: Base - Finishing
  • You can colour the pillars in any way you like, some suggestions are
    • Paper mache
    • Glitter
    • Paint
    • Cut out strips of comics
    • Cotton wool
    • sand + PVA then paint
    • Fymo characters
  • I used rolled paper to mask the LED's
  • I used flock spray paint
  • I spray varnished the paintwork to add protection.
  • Remember to turn upside down and spray the aerosol cans to clear the nossels
Step 16: Enjoy
  • Make as many pillars as you would like and........ enjoy :)
