Introduction: Kids Safety Bag
Here's my attempt at including LED lights in a kid's drawstring bag.
It could be just for fun - Kid's love stuff that lights up
Or useful for drawing attention to young pedestrians or cyclists.
Step 1:
Materials:
0.5m plaid fabric
0.5m calico fabric
3m cord
2 large buttons
Thread
1 solar LED kit with solar panel and battery pack
Equipment:
Sewing Machine
Fabric Scissors
Pins
Safety Pin
Step 2: Templates
Pin templates to fabric. You will need to cut out 1 front and 1 back, 1 pocket and two pocket flaps from fabric A (the calico) and 1 front and 1 back from fabric B (theplaid)
Step 3: Pocket Flap
Pin the two pocket flaps together, stitch sides and bottom edges, leaving top open as shown above.
Clip corners.
Step 4:
Turn pocket flap right side out and fold top edge in 1cm, as shown above.
Iron.
Step 5: Pocket Flap Buttonhole
Stitch a buttonhole on the point of the button flap, as shown above.
Step 6: LED Buttonholes
Place the button flap 10cm from the top of the plaid front bag, mark buttonhole positions for the LED globes above the pocket flap, making sure to have them evenly positioned.
Create buttonholes.
Mark the third buttonhole position below the two that you have just created, making sure to centre it.
Create the buttonhole.
Use a seam ripper to open each of the buttonholes.
Step 7:
Pin the button flap between the two rows of vertical buttonholes, making sure that it has been centred. (you should only be able to see two buttonholes above the pocket flap)
Stitch in place using straight stitch. Make sure to reverse at the beginning and end.
Step 8: Inside Pocket
Fold top edge of inside pocket over 1cm, iron.
Stitch in place using a straight stitch.
Fold over remaining edges. Do not stitch.
Step 9:
Pin inside pocket on to calico front. Centre the pocket 6cm from the bottom of the bag.
Stitch the sides and base, reversing at the beginning and end.
Step 10: Battery Pack Buttonhole
Create a horizontal buttonhole 3cm from the top of the pocket. (make sure to centre it)
Step 11:
Place the calico front and back on the table with the inside pocket facing down. Place the plaid front and back on top with the pocket flap facing up. Pin together.
Create a vertical buttonhole in each lower corner, 2.5cm from the side seam and the bottom seam.
Step 12: Stitch Bag Togeher
Place the fronts on top of the backs. Measure down 5cm from the top. Mark with a pin on both sides.
Pin around sides and bottom. Stitch with straight stitch, zig zag edges to neaten. (stitch from pin to pin, leaving the top 5cm open)
Step 13: Drawstring Casing
Zig zag neaten the open edges. Fold in 0.5cm, as shown above, iron.
Step 14:
Fold over top edge of bag front, 1.5cm and then 1.5cm again. Stitch along folded edge.
Repeat on bag back.
Step 15: Buttons
Sew button under pocket flap, making sure that meets with the buttonhole.
Repeat with button above pocket flap.
Step 16: Add the LED Kit
Place the solar panel under the pocket flap, push the wires through the buttonhole, as shown above.
Push the LED globes through the button holes above the pocket flap, making sure that the wires push out through the buttonhole above the inside pocket.
(the wires will be invisible between the plaid and calico layers)
Step 17:
This next step takes a bit of wiggling around.
Connect the LED globes from your purchased kit to the solar panel and the battery pack. The battery pack fits in the inside pocket. All of the wires should be between the fabric layers.
Trial your LEDs to make sure that they work.
Step 18: Drawstring
Cut the cord in half.
Thread onto a safety pin and push through the casing from the left across to the right and back. Thread through the left side buttonhole and knot.
Repeat from the right.
Step 19:
Your bag is ready to use. Open the pocket flap to charge your batteries. Turn on your LEDs at night.
