Introduction: Kinetic Sculpture Infinity
Hi All,
This is my third design of Kinetic sculpture, you can check my design 1 and 2 here
In this design,
- I have improved by gearbox by adding a few spacers that give stability and reduce noise
- It still is motor-based and lightweight, gathering things should not be too difficult to print and assemble.
- The wheel design is like a jigsaw puzzle easy to print and assemble.
- Wheels are reverse compatible with designs 1 and 2
- 3d Printer ( I have used Ender3)
- STL file
- M4 x 25 mm screws - 4 Nos
- M4 x 40 mm Screw - 1 no ( if you get M4 x50 or above, we need spacer2)
- 70 rpm DC geared Motor (3-6v)
- 5V volts old mobile charger
- 5.5mm male and female power connector
- Super Glue
- Box cutter
- Soldering Iron
Step 1: Gearbox Design
- To design a gearbox we must first list what we expect out
- RPM: we want (rotations per minute) rpm to be between 5 to 20
- It cannot be too fast or too slow
- We need to reduce the motor RPM to this value
- Torque: should be able to turn the and bear the load/weight of the wheels
- Needs to spin the gear anti-clock and clockwise at the same time
- Both wheels should align
- Motor selection
- There are many types of geared motors available.
- DC gear motor that I choose is commonly available
- Gear reduction
- To reduce RPM from 70 to 10, We need a gear pair with 7:1
- Motor to have minimum teeth of 10
- Mean equates that one of the gears to be 70 (let's assume the back gear)
- The front gear needs to rotate in sync with the back gear but in the opposite direction
- Added a 20T gear that is connected to the back 70T
- Added another 20T that connected to the previous 20T and the 70T front gear
- So when the motor spins clockwise, the back 70T gear moves anti-clock
- The first 20T spins clockwise, and the second 20T spins anti-clock
- The front 70T gear spins clockwise
- So we have achieved
- 10rpm
- two gears that move in the opposite direction
Sorry bit nerdy explanation
Step 2: 3d Printing
- Download STL files from here
- Print Gears with 20% infill, Layer height 0.2mm
- 10T Gear
- 20T Gear -2 no
- 70T Front Gear
- 70T Back Gear
- front_plate
- back_plate (with support)
- Infinity front wheel
- Infinity back wheel
- arms 5 sets (STL file has 4 arms)
I have added labels for easy identification of each part, If you add a query, leave a message below.
It would take 3-4 days to print it all in continuous batches
Step 3: Gearbox Assembly
- Pass an M4x40MM screw in the center hole of the backplate ( from the back)
- If you have M4x50, then use spacer 2 as shown to reduce its length
- Add 70T back gear, use super glue to stick the gear and the screw
- Let this dry
- now add 70T front gear, 20T gears, Motor, 10T gear, and spacer1
- Using 3 - M4x25mm screws fix the front plate of the gearbox
- I have added a gif file to show how the gearbox is assembled
- Connect the power supply to the motor and test how many RPMs this gearbox gives
- Mine gave 10 rpm. one could play with the voltage level to fine-tune the final rpm
Step 4: Assemble: Wheels
- The front and the back wheel have slots in a specific direction
- So the arms will fit only in a specific way, they fit like a jigsaw puzzle
- If you have difficulties in fixing them together, try to remove the elephant's foot using a box cutter
- Use super glue to fix the wheel and the arms
Elephant's Foot: For the first few layers, the distance between the hot-end and bed is less/smaller than 0.2mm, which causes the print to spread on the bed, creating these layers to be larger than the rest. A good video on elephant's foot from Makers Muse, watch it for more info
Step 5: Final Assembly and Installation
- Drill holes on your wall to hang the gearbox
- Place the wheel "back" on the gearbox, no need to glue
- Added the wheel "front" by screwing in clockwise, this will interlock with the m4x50mm screw at the center
- Switch on the power supply and enjoy your new Kinetic Sculpture and get mesmerized by its beauty
