Introduction: King Snake Paracord Bracelet
Learn how to make a King Snake Paracord Bracelet. You will need about 12 feet of paracord, and a paracord buckle. Also get some scissors and a lighter.
Step 1: King Snake Paracord Bracelet - 1
Take the first piece of paracord, lay it across the front, then with the second piece of paracord. Take it over the top of the first, behind the back and up through the hole made by the first piece of paracord. Pull it tight.
Step 2: King Snake Paracord Bracelet - 2
Take the first piece of paracord, loop it across the front so the tail comes out the same side as it starts. Then take the second piece of paracord, bring it diagnal across the front, bring it behind and up through the loop made by the first piece of paracord.
Step 3: King Snake Paracord Bracelet - 3
Then do the first braid again, Take the first piece of paracord, lay it across the front, then with
the second piece of paracord. Take it over the top of the first, behind the back and up through the hole made by the first piece of paracord. Then the second braid, Take the first piece of paracord, loop it across the front so the tail
Step 4: King Snake Paracord Bracelet - 4
Continue braiding until you reach the other buckle. Then do the first braid again, Take the first piece of paracord, lay it across the front, then with the second piece of paracord. Take it over the top of the first, behind the back and up through the hole made by the first piece of paracord. Then the second braid, Take the first piece of paracord, loop it across the front so the tail comes out the same side as it starts. Then take the second piece of paracord, bring it diagnal across the front, bring it behind and up through the loop made by the first piece of paracord.
Step 5: King Snake Paracord Bracelet - 5
Once you braid until you reach the other buckles, cut the leftover paracord off and melt the ends. Now your King Snake Paracord Bracelet is complete.
Sources:
Paracord Time.com
