Introduction: Knex - A10 Thunderbolt (Warthog)
I've had the A10 for a while now, but didn't really have the time to make an instrucable for it until now. So here it is :)
We will need the following parts:
Connectors:
-White: 5
-Yellow: 15
-Green: 1
-Red: 9
-Orange: 34
-Dark Gray: 9
-Light Gray: 2
-Tan: 18
Rods:
-Gray: 10
-Red: 2
-Yellow: 26
-Blue: 13
-White: 16
-Green: 12
Connectors:
-White: 5
-Yellow: 15
-Green: 1
-Red: 9
-Orange: 34
-Dark Gray: 9
-Light Gray: 2
-Tan: 18
Rods:
-Gray: 10
-Red: 2
-Yellow: 26
-Blue: 13
-White: 16
-Green: 12
Step 1: Create the Upper Part of the Fuselage
For this airplane, the fuselage and the cockpit will be the most difficult parts. So if you can get through those steps, then you're pretty much all set.
Step 2: Create Lower Part of Fuselage
The lower part of the fuselage is a little more complicated. I hope you can see everything.
By the way, for the red connector near the right end, don't connect it's middle socket to the bottom gray rod. Just connect to the two gray rods on the side.
Step 3: Connect the Upper Fuselage to the Lower Fuselage
Connect the bottom gray rod to the two yellow connectors, connect the two gray rods on the side to the two gray connectors, and connect the orange connector to the yellow rod.
Step 4: Create the Nose and Cockpit
Step 5: Connect the Nose to the Fuselage
This is a little tricky. I suggest connecting the bottom part first, and then working your way up to the cockpit.
Step 6: Create the Wings and Connect Them to the Fuselage
Alright we're finally through with the difficult parts. The rest will be pretty easy.
Step 7: Create the Engines and Connect Them to the Fuselage
Step 8: Create the Tail and Connect It to the Fuselage
Step 9: The Completed A10 Thunderbolt
The end product. Be careful it's a little fragile :)
