Introduction: K'nex Automatic Crossbow
After a few months I finally finished my AUTOMATIC CROSSBOW. It is fully automatic and just uses one motor to power it. It shoots yellow rods but it only shoots them around six inches. It doesn't work all of the time but it shoots once you get it adjusted right. Below is a video of the crossbow working.
Step 1: The Base.
this is just the base of the machine and one of the walls.
Step 2: The Crossbow
this crossbow doesn't have a trigger because there is a latch that disengages at that right time.
Step 3: The Wheel
when the wheel starts spinning it pulls back the string on the crossbow.
Step 4: Supports
Just some supports and some gears.
Step 5: The Hopper Part 1
This is the hopper that will hold all the yellow rods.
Step 6: The Hopper Part 2
This is the frame that will hold the hopper to the rest of the machine.
Step 7: Gears
These are the gears that will control the wheel and the hopper.
Step 8: The Latch
The latch controls when the wheel spins.
Step 9: More Gears
More gears.
Step 10: Even More Gears
Even more gears.
Step 11: VERY IMPORTANT STEP!
This is the tuning of the machine it is VERY IMPORTANT! First fill the hopper. Then remove the gear that is attaching the hopper to the rest of the machine. Then remove the gear that is attaching the latch to the rest of the machine. Then plug in the motor to the wall and wait for the string to be pulled back, and unplug it when the string has passed the place where the bullet falls out. then turn the gear on the hopper until a bullet falls out. Next turn the gear on the latch until it fires. Then put the gears back in place.
Step 12: The Top
After you put the top on it will be finished. Enjoy!
