Introduction: Knex Ball Container
About: New 2025 profile redo: (Hi guys! Sorry I haven't been active in a year! I will hopefully eventually be posting some more for you guys!) Hello fellow viewers! I'm Railfan Knexified, a local railfan and Youtuber…
Have 5 miscelanious balls strewn around your room? If so, then here is a solution! Use the knex ball container! Holds up to a good 5 balls! To fit more, all you need to do is make it longer. Doesn't take much time at all, maybe a good 10-15 minutes. I'd say if your a fast builder, maybe less! It will be portable as well, with a carry handle! Pls enjoy this construction work!
Step 1: Piece List (for a Container With 5 Balls)
Not too bad of a parts list I'd say:
Rods:
Blue: 30
White: 55
Green: 48
Connectors:
Grey 3d: 32
White: 12
Red:4
Yellow: 2
Purple: 5
Orange: 6
Others:
Blue spacers: 9
Grey spacers (same as blue spacers): 1
Grey spacers: 10
Step 2: Door
This door is for, well, the opening to the container. This is where you will insert the balls into, and taking out as well. Follow the pics and build away!
Step 3: Body (for 5 Balls)
This is the body of the container! If you have more than 5 balls, simply repeat the building way until it fits that amount. If you have less than 5 balls, simply cut off some of it and measure (see step 6). This step will include the handle.
Step 4: Back Part
The back part. Keeps the balls inside. Not really much description.
Step 5: Assemble + Add Ons
Title is description.
Step 6: Carrying
Simply lift the handle with care and now its portable! Bring it in a suitcase or a big bag, or just carry it!
Step 7: Shortening It (optional)
For any of you going to someplace for the summer and you are brining 1 or 3 knex balls with you, this is for you. To shorten it, simply take off what is on the pic and then assemble like in pic 2
Step 8: Making It Longer (also Optional)
All you need are more grey 3d connectors, green rods, white connectors, and more blue rods. (See step 3 to rebuild)
Step 9: Done!
Alright! Mission accomplished! Till "knex" time folks! Pls sub and comment! Mic drop! Ok. Bye.
