Introduction: Knex Ball Machine Element: KHAOS
Hey everyone,
Here are instructions for my biggest, most complicated element so far. This element is almost a ball machine on it's own. I wanted to call it KHAOS because it uses 4 knex balls at the same time and it's hard to understand whats going on. So if you want to know how it works you'll have to watch the video. On top of the element there are 3 separators that needs to be in a specific position so the knex balls can be devided correctly, which is explaned at the end of the instructions. It consumes a lot of pieces and works about 90% of the time. You'll need 2 special pieces to complete this build (see step 1).
If there are any problems/ questions feel free to ask me in the comments below.
Thanks for watching/ building,
Thibault Art.
Step 1: Special Pieces You Need.
You only need 1 of the black one, and a few of the orange one.
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Step 10:
Step 11:
Step 12:
Step 13:
Step 14:
Step 15:
Step 16:
Step 17:
Step 18:
Step 19:
Step 20:
Step 21:
Step 22:
Step 23:
Step 24:
Step 25:
Step 26: Important Detail #1
Make sure the arm is leaning to the right.
Step 27: Important Detail #2
Make sure the separators are in this position.
Step 28: Important Detail #3
Make sure the red connector holds the track all the way up.
Step 29: Important Detail #4
Make sure when the arm falls to the other side that it hits the grey connectors.
Step 30: Important Detail #5
Make sure the grey connector is on the right side.
Step 31: Important Detail #6
Make sure the yellow rod is between the 2 grey connectors.
Step 32:
5 knex balls are needed.
Step 33: Important Detail #6
Place 1 ball on yhe little handle like this.
Step 34:
Put 4 knex balls on the track of the separators.
Step 35: Final Results
At the end 3 knex balls should roll out the element and the other 2 balls should end up like showed on the second picture. If not, tell me in the comments whats wrong and I'll help you as soon as possible :).
