Introduction: Knex Ball Machine: Paradox, Elements
Hi everyone!
Here are the 13 new elements from my knex ball machine Paradox.
I tried to make the instructions as easy as possible to follow, and I hope I succeeded.
If you need more help or tips for your own ball machine, you can always comment or PM me.
Thanks for watching this guide and good luck with building!
~Sandroknexmaster~
Step 1: Simple Green Path
A simple element for warming up ;D
Step 2: Multi-clickers
Small wheels and vertical clickers in one. You can make it as high as you want.
Step 3: Easy Flipper
An easy flipper design, like the title says.
Step 4: Wheel Path
This is a nice element to use some of your small wheels.
Step 5: Leapfrog
A pretty big element. The first ball enters and waits for the second ball, then they both fall down.
Step 6: Confusing Ferris Wheel
Instead of a regular ferris wheel, this is a cool extra you can add. The orange spokes can be changed in every pattern you want, this is just a basic pattern to show the effect of the gears.
Step 7: Catch 'n Spin
An easy but handy element.
Step 8: Geared Double Ball Drop
A cool looking element, perfect to add in your ball machine. For this version the big green gear is needed, but if you dont have one you can modify it.
Step 9: Flat Cross-Tie Spiral
This element works best with rollercoaster track, but you can also use orange tubes.
Step 10: Bended Trampoline
A restyled rubber band trampoline with good looks.
Step 11: Simple Flipper
Simple flipper, like the title says.
Step 12: Spiral Clickers
You can make the spiral as long as you want. This one is for a standard red rod.
Step 13: Double Arm Drop
This element is originally invented by knexpert#10829476 and was first used in his ball machine ionization at 1:40 in the vid.
Here is my own version of that element.
