Introduction: K'nex Ball Machine Separator: Ratchet Arm
This is a separator I made. It has 5 outputs. It can be seen in 'The Nexus' in network 3.
Video: https://youtu.be/AM_p6pKiU5c?t=694
It can also be seen in this video as well: https://www.youtube.com/watch?v=fpoeooHWoZs
Credit goes to Samuel Hunt (1 Byte Gaming) . He was the one to create it, I have simply remade it.
This version is a bit different from original. This does not use string , and I have redesigned parts of it.
You can check out Samuel Hunt's channel here: https://www.youtube.com/@GuitaristSJH
I apologize for the horrible pictures . This is my first time making instruction. Please be polite ! I also plan adding a video to this in the future.
Addition, if you have any issue, please let me know! Feel free to message me or in the comment.
Step 1: Left Support
Simple, sturdy support tower.
Step 2: Back Support
Extra support to keep everything together .
Step 3: Support, Tracks
Additional support and tracks.
Step 4: Right Support Tower
Right side base that will hold the mechanism and more.
Step 5: Mechanism Part 1
The primary axle of the mechnism. Be sure to add the rubber band !
Step 6: Mechanism Part 2
Second part of the mechanism .
Step 7: Arm
The arm that allows the ratchet arm to rotate.
Step 8: Ratchet Arm
The arm which rotates the separator. Don't forget to add a rubber band
Step 9: Separator
This is the separator that chooses the exit path .
Step 10: Exits
4 simple exits. These can be modified to your liking.
Step 11: Return Track
This track will return the ball to the separator .
Step 12: Top Support
Support for the top of the separator.
Step 13: Entrance
This includes a switch that allows the separator to work from a single input track. This step is optional, but I recommend adding it.
Step 14: Complete
Congrats ! You have finished the separator. Make sure the switch is as position as shown .
