Introduction: K'nex Biplane
About: Two things I love: k'nex and airplanes. Two things I have: time, and a whole lotta k'nex. So I spend a lot of time building one out of the other. I like my models, so I figure why not share them with those who…
First, I want to let you know this is NOT MINE and I am NOT TAKING CREDIT FOR IT. If you've seen this before, the instructions used to be available on the original k'nex website. I build it then, and forgot about it until I found it a while ago. I enjoyed it, so I figured I'd share it with you.
This takes more bricks than anything. the color doesn't matter, but if it does to you, you can follow the image for the specific colored bricks.
Rods:
  • White: 1
connectors:
  • Purple: 1
  • Orange: 1
  • Red: 2
  • Yellow: 2
  • White: 1
Misc.
  • Green micro adapter rod: 5
  • Black wheel: 2
  • Green Brick Rod: 2
Mirco:
  • Rods:
  • Yellow: 10
  • Gray: 10
  • Red: 2
  • Connectors:
  • Purple: 8
  • Yellow: 1
  • Light Gray: 2
  • Red: 12
Bricks:
  • 10x4 flat: 2
  • 2x10: 1
  • 2x8 flat: 5
  • 2x4 flat: 10
  • 2x4: 2
  • 2x2: 1
  • 2x1: 1
  • 2x1 (with hole): 11
Step 1: Body and Lower Wing
Simply follow the steps to create the body and lower wing.
Step 2: Upper Body
This part is simple.
Step 3: Strut Supports and Upper Wing
Watch closely on where you position these pieces. Follow the images closely.
This plane is fragile, and it will likely fall apart at some point, especially if you have large fingers. Just be patient, and hopefully you'll get it sooner or later.
Step 4: Tail, Prop, and Wheels
Simply build the templates as shown, and add each part to the plane where they are shown. And now you have a model biplane. Again, this is not mine, I just wanted to share it with you.
