Introduction: Knex G36C - Instructions (UPDATE)
In the last step there is a different mag that can be use with this gun.
This is my knex G36C. Some people asked me to post instructions for it so here it is. People also asked me to make the range better, and guess wat, I DID! It was very easy: all i had to do was add a blue ring somewhere and make the trigger further bak. It shoots blue rods and i changed the handle and extended the mag. I also changed the stock by making it longer otherwise i wouldnt be able to pull back the firing pin since i put the trigger furthur back. The range of the gun will be effected if 1. you make the gun wrong 2. the elastic band pushing up the mag pusher is too tight 3. the elastic bands pushing the firing pin are not strong enough. So the way u make the gun and what elastic bands you use will effect its range. Onto the good and bad stuff......
Pros: - 40 foot range(that was the minimum i achieved)
- good looking
- i changed the handle and it looks more like the real thing
- comfortable handle
- u can add a foregrip(i didn't make instructions for one)
- has a removable mag(credit to youngcookieboy)
- has a true trigger and trigger guard
- mag holds 19-20 bullets
Cons: - has some cut pieces
- i don't know if iron sights are accurate
- uses a lot of pieces
Well i hope u like it and have fun building it. If u have any questions on the instructions or the gun feel free to ask.
Please rate and subscribe.
- good looking
Step 1: Body
In this step u are practically making the whole gun.
Follow the pics very carefully and read every image note(yellow boxes).
Step 2: Handle
You are now gonna make the handle. Follow the pics carefully and read EVERY image note.
Step 3: Magazine
Now to the magazine. Look at the pics carefully and read any image notes.
Step 4: Stock
The stock, there is nothing much i can say about it so i'll just show you the instructions. just like i've said: "follow the instructions carefully and read every image note".
Step 5: Firing Pin and Elastics
this is the firing pin I use and it works fine. hopefully it works for you too. i will only show the elastics for the trigger because im pretty sure you would be able to add your own elastics for the firing pin and mag pusher.
Step 6: You Are Done!
Well i hope ya like it. (You better!) sorry about my annoying image notes. If ya don't like something about the gun change it but dont come crying to me if it doesnt work. Just kidding. You may want to change the stock and make it shorter and/or change the mag by making it curve.
Im begging you..........please RATE(5*) and SUBSCRIBE. :)
Step 7: New Mag
This is a new mag i decided to add. It is slightly curved and should give the gun a even more real look. Hope you like it!
