Introduction: Knex Grenade (Fragmentation)
A knex grenade with a working pin.
Pros:
-Small, easy to conceal.
-Has a working pin.
-Nearly impossible for it to explode in your hand, unless you remove the pin.
-Easy to use.
Cons:
-Has a small chance to not explode when thrown.
-Somewhat hard to build/rebuild.
Step 1: Materials
Gather the following pieces:
1 rubber band
Rods:
-6 white
-3 blue (One is missing in the pic)
Connectors:
-1 white
-1 blue
-6 dark gray (optional)
Step 2: Step 1
Assemble the following:
Step 3: Step 2
Refer to video on how to attach rubber band. https://www.youtube.com/watch?v=J8xYiG-DWao
Step 4: Step 3
Assemble the body of the grenade
Step 5: Step 4 (Optional)
Remove lid and insert gray connectors.
Then replace lid.
Step 6: Step 5
Practice building this grenade (or modify it) so you can build it without referring to this instructable!.
Step 7: How It Works
1) Removing the pin allows the rubber band to move.
2) Sudden movement (like hitting the floor) releases the rubber band, allowing the fragments to fly off.
Step 8: How to Use
1) Make sure that target is within range.
2) Remove pin.
3) Throw.
It may explode in your hand if you remove the pin, and wait before throwing.
