Introduction: Knex M47 Full Stock Shotgun/Rifle (with Actual Pump Action!!)
This is a great knex gun that has an actual pump!!!
It is also now auto reloadable!!!!!!!
This gun has that great shotgun feel. Also it is a block trigger attached to a real trigger with a string. I did that because block triggers can handle the most tension. Also this way you can have a pump action shotgun that auto-reloads. It is not very complicated so anyone can build it, even begginers.
Stats:
Pump Action
Pretty Big mag
Shoots blues
shoots at least 50 ft.(with only 2 bands)
Don't Forget To Rate!!!
Here is my other video on knex guns
Stats:
Pump Action
Pretty Big mag
Shoots blues
Step 1: The Barrel, the Trigger, and the Magazine
Look at the pictures to make the barrel.
I would advise putting a rubber band now on the trigger because it will be difficult to do that latter on.
You will need decapitated grays on this.
Step 2: The Pump
Look at the pictures and build the pump.
Step 3: The Handle
Look at the pictures and build the handle.
This is one of the most sturdiest handles built.
Step 4: The Body/Frame of the Gun
This is the body/frame of the gun. i have the original body and the updated v2.0 body. just build the originall body then fix it up from the improvements from v2.0.
Step 5: Connecting the Parts
1. Connect the firing pin and the pump to the barrel.
2. Connect the barrel to the body/frame.
3. Connect the handle to the body/frame.
4. Attach the opptional ammo clip (wont be auto-reloadable)
Step 6: The True Trigger (optional)
This is an actual trigger with string attached to a block trigger.
Make sure that the string pulls the block trigger opposite the rubber bands!
Step 7: The 3 Different Versions of the Shotgun
Here are all three versions of this shotgun.
As you can see the gun is a pump action semi automatic gun now.
Step 8: Finished!!!
U are finished!!!
Now go shoot your younger sibling.
Just joking!!!
Just joking!!!
