Introduction: K'nex Micro X-Wing - Star Wars
Hello! This is my k'nex micro x-wing, and i am very proud of how it turned out.This is more of a complicated build, but almost all k'nex builders could easily build this model.Good luck and happy building!
Step 1: Parts
K'nex Rods:
1x Blue rod
14x White/Gray rods
8x Black/Green rods
K'nex Connectors:
2x Black/White semicircle connectors
4x Red Three-way connectors
4x Gray Two-way connectors
1x Gray Three-way connector
1x Black vertical Two-way connector
K'nex Clips/Other:
1x Gray K'nex One-way clip
1x Blue K'nex smooth clip
4x Black K'nex connector clips
8x Black K'nex ball joint clips
4x Red K'nex men head pieces
Step 2: The Base
As followed in the pictures. For this step, you first start making the base or hull of the X-wing, and then you work your way to the nose and cockpit.This is the longest step, but most important step of the build.
Step 3: The Wings
As followed in the pictures.In this step, you construct the four wings of the X-wing and get ready to assemble them on to the main base of the X-wing.
Step 4: Final Assembly
As followed in the pictures.This is the final step, of where you attach the wings on to the main body of the X-wing. Do note that the wings can move, allowing them to go from flight mode to attack mode, making the shape of the"X". I hope you enjoy this model as much as i do!
