Introduction: Knex P90 ~ ~KGB~'s MODDED
Hey there! This is a P90, known for it's good looks and spectacular features.... this one is the modded version of ~KGB~'s first and second P90. This is his first one: https://www.instructables.com/Knex-p90-3/ and this is his way better second one: https://www.instructables.com/Knex-p90-v2/ He gets 90% of the credit of this gun. Now you might have known Knextremist got instructions to this gun from ~KGB~, and did a really tut on this. Here is the link for his one: https://www.instructables.com/Knex-P90-Instruction... Also this is a very good gun. So he get's 5 percent of the credit, because, without him, I wouldn't have built this. So I built it from him, and then modded it, making it more stable, and making a bigger stock and a better bolt. I've also used a couple of key features from ~KGB~, like the line of sights on the top rail, and a million blue washers near the trigger area on the flexible green rod. Overall I think this is pretty much the best version of any knex gun built. Of course this is my opinion, and you might not think the same with the really bad 10-20 foot range. But if you built this, you could upgrade the trigger and make it actually PULLABLE, because you need about 5 pounds of push on that trigger. So that's why I upgraded the trigger from ~KGB~'s not very stable one. Its stronger. You don't need any random rubber bands holding together loose bits to the gun, which I really don't like in knex guns. The stock holds masses of "Blue Ammo" (52 mm rods); I estimate around 100-150 of them! So now I'll start with the pros and cons stuff. As you already know some....
Pros:
Bigger stock, estimated 100-150 52 mm rods
Cool line of sights, edited from ~KGB~
A more stable version of his ^ and Knextremist's P90
Also a more stable trigger
I think really epic looking
Really comfortable handholds/grips with tires and stuff
A way more stable bolt and a better firing pin
Hopper fed
Stores 10 bullets in mag
Overall really epic
Cons:
Shoots bad: 10-20 feet
Impossible-to-pull trigger
Lots of pieces used
The whole bottom half of this gun is really flimsy
And, I didn't post an instructable about this :(
It would take too much time to make an instructable on this. But anyways, I already said, this is an EPIC gun!
Comment if you like it! Thanks for viewing it, and share it with.... not going into that.... (This isn't even the surprise I posted on the instructable before the one before this!)
~Blitzx~
