Introduction: Knex POG (Push Operated Gun)
A Knex gun that doesn't use any rubber bands.
Pros:
-Small.
-Has a magazine for easy reloading
-Doesn't use any rubber bands.
-Short reload time.
-Easy to modify.
Cons:
-Short range compared to other guns that use rubber bands.
Suggested use: For demonstration purposes, or a gun attachment.
Link to pistol version (CLICK HERE)
Pros:
-Small.
-Short reload time.
-Easy to modify.
Cons:
Step 1: Step 1
Gather these pieces:
Connectors:
4 yellow
1 dark gray
1 tan
8 red
Rods:
4 blue
1 broken rod a little longer that a blue rod
1 green (optional)
Connectors:
4 yellow
1 dark gray
1 tan
8 red
Rods:
4 blue
1 green (optional)
Step 2: Step 2
Assemble the following:
Step 3: Step 3
Put the two parts together. Observe the direction of the yellow pieces.
Step 4: Step 4
Build and attach the mag holder.
Step 5: Step 5
Assemble the mag.
Step 6: Step 6
Attach the mag as shown. Pull the handle out and slide all of the bullets to the right to reload.
Optional: A green rod can be inserted inside the red piece so that it is behind the top of the bullet. This will increase power and range, but it will be less accurate. It may also break the bullets.
Firing:
Push the trigger toward the handle.
Parts:
Yellow connector on far left- Trigger (not really a trigger)
Yellow connector closest to the blue connector- Handle
Circular hole in the red connector (closest to the blue connector)- Green rod compartment.
If you have any questions, please PM me.
Firing:
Parts:
