Introduction: K'nex Piece Launcher
Step 1: Intro
In my first how to i will show you how to make a piece pusher ( sorry for ban quality taking this on my iPhone )
Step 2: Equipment
First you will need a yellow connector, 4 yellow rods, 1 white connector, 2 red rods, 1 purple blue connector ( will be in picture ) and 1 elastic ( small )
Step 3: Phase 1
First you will need to connect the blue purple connector to one of your reds
Step 4:
Step 5: Phase 1 Step 2
Now that those are connected put the white connector like so
Step 6: Phase 1 Part 2
Now put yellow connectors like so
Step 7: Phase 2 Part 1
Clip the yellow connector two the top off the red
Step 8: Phase 2 Part 2
Attach the unused red to the opposite side of the way the yellow is pointing
Step 9: Final Phase !!
Now you ready to add the elastic to to the pusher, to attach put on 2 rod spots on the purple blue connector and on the inside between the closest 2 yellow rods
Step 10: Your Ready to Fire
Now all you have to do is find you ammo and load I personally use the white connector I will show you how to load
Step 11: Loading Step 1
To load pull back the blue purple connector
Step 12: Loading Step 1
Now put your ammo on the red rod like so
Step 13: Firing the Weapon
When you want to fire load pull back connector
And releases and it will fire
Step 14: Finishing Up
Well that was a k'nex piece pusher if you have any problems leave a comment that states the problem and make a troubleshooting how to fix it you can add a scope but I didn't as well leave the arcamada and the pice pusher in the background I say.......
Step 15:
Byeeeeeeeeeeeeeeeeeeee shoutout for my friend
