Introduction: Knex Pistol
This is my new set Knex instructable. It is also my first Knex gun, so go easy on me
Step 1: The Barrel
You will need: 12 yellow connectors, 2 Orange connectors, 12 white rods, and 1 blue rod.
Step 2: The Handle
You will need : 2 white connectors, 2 green connectors, 1 red connector, 5 white rods, and 2 green rods
Step 3: The. Firing Mechanism
You will need : 2 purple connectors, 2 red. connectors, 1 orange connector, two blue rods, and 1 red rod.
Step 4: Putting It All Together.
You need everything you've made so far and two rubber bands
Step 5: Add Ons
Step 6: Firing
To fire, you have to pull out the blue rod holding the firing rod in place. Then you pull back on the firing rod. Next you put the rod back into either the third or fourth hole on the barrel, depending on where the purple connectors hole is. Then you load your ammo so it is in front of the firing rod. I used yellow connectors as ammo. Then you pull the blue rod out again to fire.
