Introduction: Knex Pump-Action Shotgun PAS2000
Hello guys,
I'll show you how to make an easy knex shotgun.
with a pump-action system, so you can reload very easy
and fast !!
- it shoots about 50 ft !
- the magazine holds 20 rounds
- you can reload the magazine in 70 seconds
- you can shoot very fast !! (the whole magazine in less than 40 seconds)
Step 1: The Barrel
the barrel is not necessary, it is just for make it look cool
1) make 1 of this
2) make this 5 times
3) make this 2 times
4) Add everything together
Step 2: The Grip
this is the foregrip:
1) make this 1 time
2) make this 2 times
3) make this
4) add everything together
Step 3: The Magazine
this is the magazine
it holds 20 rounds and it almost never blocks
it is very easy to reload.
1) make them both 2 times
3) add everything together with white rods
4) make this
Step 4:
1) make this
2) add this
3) add them all together
Step 5: The Trigger
this is the trigger:
1) make this one time
2) maek this 2 times
3) make this
4) add 1,2,3 together (1 in the middle )
5) make this
6) add 5 together
7) another picture of 6
8) add the two parts together
Step 6: Handle/ Pushpin
this is the handle you'll need for relading
1) make them both 3 times
2) use 1 to make this
4) make this
5) add 3 to 2 on both sides
6) add 4
7) make the pushpin
8) make this
Step 7:
make this 2 times
Step 8: The Back
this is the back
1) make this 2 times
2) add blue rods
3) make this
Step 9: Assembly
add all the steps you have made before
1) add the magazine and step 4 together
2) add the trigger
3) add this part (see note)
4) add step 7 on both sides
5) add this part (see note)
6) add the barrel
7) close up from the barrel (pay attention on the connection !!)
8) add the grip
9) add step 6
10) add the back of the gun
Step 10: Adding Rubber Bands
1) sometimes you must connect 2 rubbers, use th reef-knot
2) add rubber bands to the gray connectors
3) use step 2 for the magazine
4) add rubber bands to the pushpin (remove the back while adding the rubber bands)
5) put the back on again
6) add rubber bands to the handle
7) add a rubber band to the trigger
Step 11: How to Reload
this is how to reload, it is very easy !!
1) open the magazine
2) move the magazine pusher over here
3) fill the magazine with blue rods, move the pusher, close the magazine and done !
