Introduction: Knex Rbg Pistol
pros
Simple trigger mechanism
Okay range with good rubber bands
Easy to make
Cons
Cannot be made into a semi automatic
Breaks rubber bands ( I had weak ones that snapped after 10 shots)
Easy to make
Cons
Step 1: Trigger and Handle
This is the trigger and handle follow the pics and you should be okay.
Step 2: Barrel Start
The easiest step, make two barrel segments and connect them to the handle, this evens the barrel out so you can attach the barrel without a hitch.
Step 3: Barrel
The hardest step make all the segments and connect them. ( the red rods that come out of the bottom are optional the just add a secondary handle.
Step 4: Bands and Firing
Put a band around the trigger, put a band on the ammo wheel, hook it at the end, and shoot.
