Introduction: Knex Revolver
This is my first instructable, so lets get started. I got the idea from Spryans gun. I do not take full credit because i kept sum of his ideas including the handle and cylinder. Other than that i believe the design was mine. Read descriptions for each step for clearer instructions.
PROS
Okay range
8 rounds
Iron sights
Strong frame
Pretty accurate
Rounds don't fall out of cylinder
CONS
No true trigger(aaaggggghhh Trust me Ive tried)
If you pull the firing pin to far it will fall out
that's all that i can think of
Piece Count
Connectors
Grey(one side): 23
Orange(two side): 8
Light gray(two side): 8
Purple(three side): 2
Red(three side): 1
Green(four side): 5
Yellow(five side): 8
Blue(seven side): 4
White(eight side): 2
Rods
Green:21
White:12
Blue:4
Yellow:2
Red:none
Grey:3
Other
Grey Spacers: 36
Y clips:5
Tape (Recommended Duct tape)
Some rubber bands
any rod your willing to mod
Front sight requires these unless you modify:
A snow flake and 8 blue rods just for the cylinder, you dont need them permanently just for one step
PROS
Okay range
8 rounds
Iron sights
Strong frame
Pretty accurate
CONS
Piece Count
Connectors
Grey(one side): 23
Orange(two side): 8
Red(three side): 1
Green(four side): 5
Blue(seven side): 4
Rods
Green:21
White:12
Blue:4
Yellow:2
Red:none
Grey:3
Other
Grey Spacers: 36
Y clips:5
Some rubber bands
Step 1: Cylinder
This is the hardest step so lets get it over with. For this step you will need the tape and the white snowflake with blue rods attached. First make 9 of these... then put tape around the SPACERS only.Once you've put tape on all of them put them on the snowflake with blue rods attached. You should be left with one thing of spacers left. Put tape around this until it is snug in-between all of the spacers.After wrap whole thing in tape.
Step 2: Handle
Step 3: Main Frame
Step 4: Barrel
Step 5: Top Barrel
Step 6: Everything Else
Make these
