Introduction: Knex Robot Wars Thor
Thor. the fast and red robot that has always had problems with his CO2 system. as mostly a dreamer, it took me 5 months to perfect the design. it features a breakable bumper on the front that is required to cushion any impacts that hit the front of the robot. the actual robot just has a wedge, not a bumper, but my bumper works as a wedge as well.
Stats:
Strength (armor): 7/10
Strength (weapon/ax): 10/10
Strength (ax shaft): 10/10 because of the bendy-rod shaft locks.
i give anyone permission to recreate and re-post this build for themselves, as long as the design is changed.
Rods:
Green: 0
White: 27
Blue: 55
Yellow: 37
Red: 2
Grey: 0
Flexi-rods:
light blue: 1
light purple: 0
orange: 2
clear/metal-tip: 0
green/purple: 1
Gears (any wheel will work as well, but i was running low on wheel so used gears instead):
Small: 0
Medium: 2
Large: 0
Connectors (number of slots in brackets):
pins, any type will do (1): 14
"Y"s (2): 6
Red (3): 3
Green (4): 12
Grey/Purple, that clip together (4): 26 sets (52 pieces)
Yellow, tabs don't matter (5): 38
Blue, that clip together (7): 0
White (8): 0
Step 1: Bumper/Wedge
1: make
2: make
3: connect on both pieces, alternately
4: A view showing the alternating sides
5: make
6: connect
7: connect
8: Robot so far
Step 2: Side Walls
1: make x2
2: make
3: make
4: connect
5: connect
6: get
7: connect
8: connect
9: make another one identical to the first, but facing the other way
10: connect
11: Robot so far
Step 3: Axe Mount and Center Roof
1: make
2: make
3: make
4: connect
5: make
6: make
7: make
8: connect
9: connect
10: make
11: connect
12: the whole piece
13: get
14, 15, 16, 17, 18: attach all
19: robot so far
Step 4: Bottom Armor
1: make
2: get
3: flip over
4: attach
5: robot so far
Step 5: Rear
1: make
2: make
3: connect
Step 6: Axe
Very tricky as i did not feel like hurting my poor fingers again to take it all apart... OuO
all pics are just different angles of the axe to assist you in building it. good luck!!!
Step 7: Assembly and Use (video)
get all and put together axe is used by hand. and you are done!!!
