Knex Shotgun - Revenge - Build!
Introduction: Knex Shotgun - Revenge - Build!
About: Hey, my name is Jay. I've been working on building a lot more lately, expect more Instructables later on!
I've wanted to build a shotgun for a while, so I did it, but now I need to destroy it for parts...but at least I'm making instructions before I do!
Quick Notice: This gun uses roughly 5 broken rods (3 connectors wide) and 3 end clips, you can replace them all without problems (You will have to move pieces around/take some off) so don't worry too much if you don't have them. Also, green rods mean that specific part cannot be seen from outside of the gun, black rods mean you can see that part. (Not important unless you color code or use specific pieces)
I apologize for the Blur and Shade in some pictures, I don't have the best camera quality or lighting.
Enjoy!
Step 1: Blast Barrel
This Is probably the most important part of the gun, It holds the pop-up sight and the main firing mechanism.
1. First Layer of the Barrel
2. Build These
3. Add them Here
4-5. Build This
6. Add it Here
7. Build These
8. Add Them to the Barrel
9. Add This Here (From Picture 7, Don't Forget the White Rod)
10. Connect the Last Piece
11. Add it on
12. Another Angle
13-14. Build the Trigger
15. Add it Here
16. Build These
17-18. Place it in Between the Yellow Connectors and Slide it in
19. Add This Piece (From Picture 16)
20. Add This on Afterwards
21. Build These
22. Connect the 4th Layers
23. Add the Final Layer On (I Would Recommend Adding them 1 by 1)
Congrats! You've Finished the Blast Barrel!
Step 2: Handle
Another Required Part of the Gun, When Firing, make Sure you Move your Hand Down the Handle so the Firing Pin doesn't hit your hand.
1. Build This
2. Build These
3-4. Connect Each Side
5. Build These
6-7. Add Each Side
8. Build These
9-10. Add Each Side
11. Get a Rubber Band
12. Add it onto the Handle
13. Get the Barrel and Remove these Pieces
14. Add the Handle onto the Barrel
15. Add the Pieces Back on
16. Add Another Rubber Band onto the Trigger
Congrats! You've Finished the Handle!
Step 3: Break Barrel
This is the Part that will make your Gun Break open to load.
1. Build This
2. Build These
3. Attach Like So
4. Build These
5. Add them Here
6. Build This
7. Attach Here (Get a Rubber Band)
8. Slide the Band Through Here
9. Build These
10. Attach Here
11. Build These
12. Attach them Here
13. Build the Final Layer
14. Add It on
15. Add this Purple Connector (Also Notice where the Band is)
16. Add an End Connector
17. Grab a Blue Rod and the Blast Barrel
18. Connect Like So
19. Get These Pieces
20. Add the Blue Clip Here
21. Add the Black/Green Connector Here
22. Close the Barrel
Congrats! You've FInished the Break Barrel!
Step 4: Stock
This Part isn't Necessary, but it Provides Support, Looks, and More Grip Area.
1-4. Build This, All Layers are the Same except for the One White Rod at the Front (Sorry, I was too Lazy to take it Apart)
5. Build These
6-7. Add Them on Like So
8. Build These
9-10. Add Them on Like So
11. Get 3 Rubber Bands
12. Add Them onto the Stock
13. Add the Stock onto the Main Body
Congrats! You've Finished the Stock!
Step 5: Fore Barrel
This Part also is Unnecessary, but Makes the Gun looks Cooler.
1. Build This
2. Build These
3. Add them on Here
4. Build This
5. Add it on Here
6. Build These
7. Add Them on Here
8. Build These
9. Add Them on the Other Side
10. Get 3 Rubber Bands
11. Put the Rubber Bands Here
12. Connect it to the Main Body and Get a Blue Rod
13. Put the Blue Rod Here and Move the Rubber Bands Over
Congrats! You've FInished the Fore Barrel!
Step 6: Firing Pin and Rubber Bands
Final Step! You're Almost There!
1. Get 2 Rubber Bands
2-3. Add them on Each Side
4. Firing Pin
5. Wrap in Tape
6. Wrap in Rubber Bands
7. Put the Pin Through the Barrel
8. Get a Few Rubber Bands
9. Add them on Each Side
How to Shoot
10. Pull the Pin Back
11. Break the Barrel Open
12. Place a Yellow Rod Through
13. Close the Barrel
14. Fire!
Congrats! You've Finished the Gun! I Hope you Enjoy it and Fire as Much as you Want! (Please Don't Shoot at anyone's face, I'm not responsible for any injuries) If yoy have any problems, feel free to message me!
Be the First to Share
    • Retro Tech Challenge
    • Plastic Challenge
      Plastic Challenge
    • Organization Contest
