Knex 'Slider' Ball Lift
Introduction: Knex 'Slider' Ball Lift
About: I'm into knex ball machine stuff. My favourite parts are lift/element hybrids, probably because I tried building a perpetual ball machine. It didn't work, of course. All my knex stuff is creative common, and …
This lift is quite like the 'alternator' lift, but at a 45 degree angle. It's also a lot more piece efficient.
It is also easily modified to get higher.
Video: http://youtu.be/LB3ykR_vr-I
Step 1: Making a Scaffold
This scaffold will be made of 'cubes' and a slope down the side.
Part of the scaffold is left out, on the black rods around that there are dark grey connectors.
There is also a small ramp at the orange connectors, a yellow connector at the top, and extra base at the bottom, front.
Step 2: Moving Part
This is the bit that slides up and down.
Step 3: Adding That
Clip the previous step onto the dark grey connectors in the gap.
Step 4: Roof
This is the part that goes above the slider so the ball doesn't go down.
Step 5: Attaching the Roof
Attach each of the blue rods to the scaffold.
Step 6: Entrance Track
This is where the ball enters the lift
Step 7: Adding the Entrance
There are six places to connect the green rods.
Step 8: Motor Parts
This is the crankshaft and the motor.
Step 9: Putting It Together (Finished)
There are five connections to make.
Step 10: What If Your Slider Is Jamming?
Put a spacer on any of the red rods like in the pictures.
1 Person Made This Project!
  • For the Home Contest
  • Game Design: Student Design Challenge
  • Make It Bridge
    Make It Bridge
18 Comments
Knexified
Knexified
1 year ago
Would this be able to be made wider for more than 1 spot if you have more pieces (or enough)?
mathsboy314
mathsboy314
Reply 1 year ago
You could give it a try but I suspect it wont work. This design isn't good at handling many balls at a time.
Knexified
Knexified
Reply 1 year ago
Ok. I'll see what I can do.
knexpro7575
knexpro7575
Question 1 year ago
Can you use the green motor in this lift? I threw out the slow motor since one of the batteries exploded.
mathsboy314
mathsboy314
Answer 1 year ago
Yes, but it might be unstable. I suggest that you add some extra scaffolding to hold it in place.
mathsboy314
mathsboy314
Answer 3 years ago
Sorry dude, I don't have a piece count.
I designed this lift so you can extend it to any size.
You also can skip steps 6-7 (the entrance track) and let the ball start anywhere.
Step 1 (scaffold) is only a suggestion, and should be replaced according to the design of your ball machine.
For these reasons, it's hard to determine how many pieces are needed.
bennett2198
bennett2198
5 years ago
I made this. It works very well. I like the way it pushes the balls up. I made a video of it lifting up 3 balls at a time. It handled them quite well.
Neat lift, I like the fact that it uses waaaaay fewer pieces than Shadowman's Alternator Lift (which always kept me from building one). Although the movement appeared in the video to be slightly delayed with more balls, I consider this a well-crafted lift. Great job!
mathsboy314
mathsboy314
Don't worry about the jumpy movement. I've edited it to remove that in step 4 (see tags)
Works very good, I'll use it in my next ball machine.
It took me only half an hour to build.
KneXtreme
KneXtreme
10 years ago on Introduction
Very ingenious! I like how the balls can enter from any point.
