Knex Small Assault Rifle
Intro: Knex Small Assault Rifle
Alpharex here, with my latest creation!
It is the new Assault Rifle!
Pros: Light, Small
Decent Range
IT FIRES WHITES! GASP!
Uses little parts
Large Mag
Mag doesn't jam
TRUE TRIGGER! :D
Cons:
Bad Handle
The stock may make pulling the ram rod back difficult. (That's why the Stock is optional.)
Mag Pusher Sticks out of the Gun.
BUILD AND COMMENT!
Pros: Light, Small
Decent Range
Uses little parts
Large Mag
Mag doesn't jam
TRUE TRIGGER! :D
Cons:
Bad Handle
BUILD AND COMMENT!
STEP 1: Barrel
Simple Step. It's in the pictures.
1. Top View
2. Side view
3. Direct Side View
4. Bottom View
1. Top View
2. Side view
3. Direct Side View
4. Bottom View
STEP 2: Stock (Optional)
1. Omniscient view
2. Side View
3. Bottom View
3. Uh... Other Bottom View?
2. Side View
3. Bottom View
STEP 3: Scope
Very easy to make.
1. Side View
2. Front View
1. Side View
2. Front View
STEP 4: Handle
Simple, yet crappy.
STEP 5: Trigger
1. Front View
2. Side View
3. Back View
4. Side View
5. Detailed Top view
2. Side View
3. Back View
4. Side View
STEP 6: Magazine
Self-Explanitory.
1. Side View
2. Side-Top View
3. Top View
4. Bottom View
1. Side View
2. Side-Top View
3. Top View
4. Bottom View
STEP 7: Body
This is the hardest step....
You may want to look at all the steps FIRST.
1. Side view
2. Front View
3. Top View
4. Bottom of the Body
5. The Middle of the Body
6. The Top of the Body
7. The Front Portion of the Body, and a closer look at the modified gray connectors.
8. Side View of the Top Portion.
1. Side view
2. Front View
3. Top View
STEP 8: Ram Rod and Mag Pusher
Simple.
Oh yeah, you need to tape the ram rod. A lot.
STEP 9: Putting It Together
1. Add on the Barrel to the Body
2. + 3. Put the Mag on.
4. Trigger goes there.
5. Put the Trigger and Handle on.
6. Attach the Stock. (optional)
7. + 8. Put on the Scope.
9. + 10. Insert the Ram Rod.
STEP 10: Elastics
1. Trigger Band.
2. First Ram Rod Band.
3. Second Band.
BTW: You need one more for the Mag Pusher, which will be explained in the next step.
3. Second Band.
STEP 11: Loading/Firing
It fires whites! Yay!
Anyway, you load them in through the mag.
Then push the bullets all the way up.
And attach a band to the Mag Pusher.
To fire, pull back the Ram Rod until the Trigger pops up.
Press the trigger to fire.
Done.
Done.
52 Comments
Baxblitrix 2 years ago
Baxblitrix 3 years ago
yoaveangell 3 years ago
elwoodknight 11 years ago
KnexFreak360 13 years ago
metroid9 14 years ago
Liberty Prime 14 years ago
james4 14 years ago
KNEXFRANTIC 14 years ago
ub3rc00k13 14 years ago
~Z~ 14 years ago
Pizzapie500 14 years ago
travw 14 years ago
*2
Sorry
