Knex Smg (instructions)
Intro: Knex Smg (instructions)
This is my knex smg that i posted awhile back but as an instructable.
It fires white/silver rods through the magazine yellow/brown rods are recomended which can easily be loaded in through the end of the barrel.
Features:
good looks
smalll
lightweight
easy to reload
good sights
accurate at short range
comfortable
cheek rest
new stock rest
stock and handle can be removed for better manouverability
easy to pull apart
can add sights
has places for straps
has a charging handle (just for looks)
This gun is very easy to build so just follow the pictures and should be done in no time.
Please rate,comment, subscribe and be sure to check out my other creations.
Features:
good looks
smalll
lightweight
easy to reload
good sights
comfortable
cheek rest
new stock rest
easy to pull apart
can add sights
STEP 1: Receiver
relatively simple
NB This part uses 7 broken grey connectors
STEP 2: Body
Simple.
STEP 3: Barrel
STEP 4: Magazine
Curved magazine - mainly for looks and hard to use when firing from the magazine.
Straight magazine - Fits better in the well and should be used when shooting from the magazine.
STEP 5: Stock
Image 6,7 : cheek rest
Image8,9 : Stock rest
image 10 : use the part from pic 8 to stop the rest from moving.
STEP 6: Trigger, Rear Sight and Firing Rod
The orange part on the trigger must be broken.
The rod end has been shaped using a pencil sharpener and knife (This makes it easier to pull back and lock the trigger)
WARNING USE KNIVES SAFELY
STEP 7: Foregrip
1,2 : foregrip
3,4 : bipod
5,6 : connecting the bipod to the grip
7,8,9 : steps to attach the grip. NB (the rod with gear must rotate to add or remove grip)
3,4 : bipod
STEP 8: Assembly
Attach parts in shown places
2 : trigger goes here
3 : slide in the trigger pin
4 : attach this piece on other side (i dont know what the piece is called)
5 : attach the trigger guard
6 : firing rod goes here
7,8 : Magazine placement
7-put magazine in at an angle
8-push magazine in direction towards trigger to lock in place
9- front strap connection
10-rear strap connection
STEP 9: Adding the Lackeys
i use use #64 for firing rod and #14 for trigger and charging handle
1,2 : top band
3 : bottom band
use 2 bands along top and 2 on bottom.
4,5 : trigger band
6 : charging handle band
7: attach the rear sight after the rubber bands have been put on
1,2 : top band
3 : bottom band
4,5 : trigger band
STEP 10: Extra Sight
This is just a modified fake reflex sight i saw somewhere
pic 4 is my real reflex sight
25 Comments
maxisgood135 2 years ago
carworld11 3 years ago
PlatinumUndefined 2 years ago
patrickgdawson 3 years ago
shaisley 3 years ago
TheKnexChicken 8 years ago
you were lazy and didn't want to completely disassemble your gun XD no one can make it cuz you don't show how to make the parts less they are eagle eyed
Rubymatrix321 6 years ago
yes
Ethan1023 7 years ago
Looking at Step 5: Image 6/7 (Cheek rest, as you called it), if you reversed the order of every other dark grey connector, the structural integrity would be greater.
tedbear2 11 years ago
CallumC2 8 years ago
MADE MY DAY
X-D X-D
That_Jamie_S_Guy 8 years ago
turdus_migratus 10 years ago
lemonpickle 11 years ago
hawk45 10 years ago
Mr._Rodgers 11 years ago
PotatoCoffee 11 years ago
DJ Radio 11 years ago
mr.knexer 11 years ago
didexo 11 years ago
~Meme~ 11 years ago
