The Special Knex Sniper Rifle
Intro: The Special Knex Sniper Rifle
My sniper is a mix of a AWP and many other snipe rifles. I completely destroyed my thumbs while building it. I personally think it looks pretty good but i could make it look better if i had more pieces. For example, the muzzle and the stock. This gun shoots orange connectors to purple connector bullets.
Pros: -Shoots really well if you put enough elastics
-Comfortable grip and barrel
-Looks good (I think)
Cons: -The stock and muzzle are a bit fragile
-Takes a while to reload
-The scope can sometimes be in the way of the bullet
PS: I am a 12 year old kid, so if i can create this, you can build it! :)
STEP 1: The Body
The body consists of 5 layers. The bullet is propulsed from there (under the scope).
STEP 2: The Stock
The stock is only attached to the two last layers of the 5 layer body. It doesn't use a lot of pieces wich is good because i'm running low om them.
STEP 3: The Muzzle and Barrel
The muzzle can be made longer but i don't have any orange connectors left. You can customize the barel by taking off the "wheels" wich in this case are use as grip.
3 Comments
LittleBilly 6 years ago
Oddice 6 years ago
Only if i had more pieces i could make an actual bipod, stock and muzzle
