Introduction: K'nex SpaceX Crew Dragon Capsule
About: Hello, this is s0200311. I have been building with K'nex for years. I have a lot more projects on my website, https://www.andrew.r3tic.net
Hello,
In this instructable you will be able to make the Crew Dragon 2 capsule from SpaceX. It is compatible with my SpaceX Falcon 9 Block 5 rocket, which is here.
Step 1: Parts Needed
To make the Crew Dragon 2 you will need:
RODS:
3 white rods
3 black white-length rods
1 purple micro adaptor rod
7 black shortest micro rods
CONNECTORS:
2 white 8-point connectors
1 grey 4-point snap-on connector
1 grey micro 7-point snap-on connector
1 blue micro 4-point snap-on connector
10 grey micro 4-point connector
CLIPS:
6 micro y-clips
To add fire from the small engines on the crew dragon 2 you will need, in addition to the parts above:
RODS:
4 black micro rods
CONNECTORS:
4 micro orange 2-point connectors
CLIPS:
4 micro y-clips
Step 2: Building the Crew Dragon 2
This step is fairly easy. Remember this is useless without the rocket to go under it! The link for the rocket is here.
Step 3: Fire and Finished!
Here are the instructions for the fire from the engines, if you want. Other than that, you are finished! If any of you have an idea for a payload for my Falcon 9 Block 5 rocket, I would be open to the suggestion. See yall later!
