Introduction: Knex Suspension Pickup Truck **Suspension Upgrade/Mod #1**
Step 1: Suspension
OLD VERSION -Follow the steps to make each individual suspension unit. Your will have to repeat the steps 4 times. In total your will have 2 of the piece in this picture. One for the front and one for the rear.
NEW VERSION- Go to step 9 and make 4 of these units. Connect 2 units together with white rods. This will give you a front and rear suspension unit.
Step 2: Front Chasis
This should be pretty easy to build.
Step 3: Rear Chasis
completing the rear chasis
Step 4: Some Assembly
Putting the front and rear chasis together. Add the wheels.
Step 5: Hood, Grill, Headlights, and Bumper
Assemble the components that will make the truck look good.
Step 6: Side Panels
The side panels need to be made. Meke one for each side. Add the doors with a simple snap.
Step 7: Roof
Pretty easy.
Step 8: Final Assembly!
Now for the fun part. I think you should be able to see how each component is added. I ran low on battery in my camera so I tried to conserve the power by taking as few pictures as I thought I needed. I have modified my own truck since I built this one. It is now a six wheeled box truck with massive suspension and a rubber band powered opening back door. Why? I really don't know.
Step 9: Suspension Mod #1
This suspension is a lot less fragile than the previous version. It requires NO Y connectors and no further modification to the truck. It requires only a few spacers to be moved. The rubber bands are also much easier to get to meaning it is easier to adjust.
127 Discussions
Question 2 years ago
can someone post a piece inventory?
8 years ago on Introduction
your truck looks brilliant! ima build it once im done building my rifle....
9 years ago on Step 9
I've used this on a k'nex atv, and it worked great. What I did do though, was switch the yellow connectors that the wheels connect to for white ones for to increase the height, although this requires 2 of the 'spokes' to be cut off to allow the suspension to move.
Reply 8 years ago on Step 9
this would be even more amazing if it had larger tires, that said it is still amazing as it stands
(haha, i just realized how late this comment is)
The best truck with suspention so far!! and 5*****
cool i used to really be in to knexing but havent really done it in a while bu i think ill try this when i get some free time
9 years ago on Introduction
I've designed a spring suspension the same size as this, I might be posting instructions. But I've also made a brilliant trailer that should fit this, so I will definatly post some instructions for that!
I would like to see both. I will take a look when you post them.
I've complete the trailer instructable here's the link! (https://www.instructables.com/id/Knex-Trailer/)
This is very good. maybe check out my monstertruck with suspension.
https://www.instructables.com/id/Knex-Monstertruck/
pretty simple A arms up front, you can put them at any length you want..the only defect about longs arms like these is they tend to bend back when pressure is applied to them at a certain angle..you can kind of see a gray long rod on the buggy leading from the rear arm mount up to the front A arm as it help ALOT by keeping it in place and not bending back..the trophy truck front arms dont really need it as they have alot more hot glue on them and are sturdier.
so is the supension prety strong
I just made this step 9 suspension mod for my truck that i made and it works GREAT really good design.I put my 3 1/2 inch tires on it that i ordered my Knex.com and it still works very good. i have a motor on the back of the truck but im gonna try to figure out how to make it have a motor and suspension as well...Any Tips on how to put suspension and a motor on it? Please reply(:
Reply 9 years ago on Step 9
I wish I had some ideas for the motor/suspension but I have had no luck. I have tried everything I could think of. I think there may just no be a way for it to work at this scale. The best way would be to have some sort of drive axle but I don't know how that would work. You could try rubberbands/chain to make a pulley type system but it would not look good. I am really out of ideas. If you can think of something that works, please post it. Good luck!
I've used your suspension and put steering on it :))
9 years ago on Step 6
i ran out of those single grey pieces :)
what if you dont have the right size tires can i use other ones that are slightly smaller?
It should work but it might look a bit funny.
k just wondering
10 years ago on Introduction
I think I was checking the tire pressure of my car one day when I took a look at the suspension. I decided to try to convert the real suspension to a knex version. I tried many times but couldn't really get anything that was strong or reasonably sized. I had the eureka moment when I snapped the grey and yellow connectors together in that interesting way. Once I had that I knew I could many small but realistic independent suspension. If only I could come up with such an innovation to allow for steering.
