Introduction: Knex Three Small Gear Connection
This is a compact and strong way to connect three small Knex gear when a large gear cannot be used and staying in the Knex geometry.
You need three axles, three small gear, green connectors, interlocking clips, some spacers and any piece/connector will do to hold it all together.
Step 1: Combine Basic Pieces
I use these white pieces to form the body. Attach green connectors as shown.
Step 2: Add Gears and Axles
Put small gears on the axle with interlocking connectors.
Step 3: Add Middle Axle and Handle
Put the light blue gear on the middle axle. It seems only the light blue gear runs freely on an axle. Add the turning handle.
Step 4: Place the Axles
Connect the white pieces and put the axles in.
Step 5: Place the Middel Axle
Add the middle axle and push it under the green connectors.
Step 6: Place a Spacer
Detail of how the middel axle is out in and supported. Mind you put a blue spacers in. It may seems unnecessary, bur i t holds the middle axle securely in place.
Step 7: Finishing
Place the handle. Look at the different views. Happy turning!
