Introduction: K'nex Tilt Table
Hi. As my first instructable, I'm here with a tilting marble labyrinth - The Tilt Table. You can customize the maze on it however you want and I noticed that the table can be used as a boxing rink. For the boxing ring, only build step three. Have fun with it!
Also, as this is my first instructable, feel free to comment but i would like no inappropriate language please, thank you.
Step 1: Piece Count:
The piece count on this model isn't very big and it can be changed depending on how big you want the table to be. If you want to make a bigger sized model, replace the blue rods for yellow, the yellow rods for green/red rods and the green/red rods for grey/blue rods. You will also need a Large Piece of Cardboard with a size of 20.5 by 20.5cm OR 29.5 by 29.5
I would also suggest that if you want to make it you should get the pieces beforehand.
I may be slightly inaccurate here so please excuse me.
Rods:
Yellow - 18
Green/Red - 4
Blue - 8
White/Silver - 17
Black/Green - 14
Connectors:
Small black with clip - 2
4-point locks - 45
7-point locks - 9
5-point - 4
2-point (opposite ends) - 6
1-point - 1
Other:
A Ball (I use the old k'nex balls) - 1 or more
Blue Spacer - 2
For the Labyrinth Roof and walls:
Blue/Grey Rod - 8 Least (more are optional)
For Each Wall Segment:
Green/Black Rod - 1
2-Point Connector (opposite ends)
5-Point Connector - 1
And 1 green/black connector to join segments.
Rods:
Yellow - 18
Green/Red - 4
Blue - 8
White/Silver - 17
Black/Green - 14
Connectors:
4-point locks - 45
7-point locks - 9
5-point - 4
1-point - 1
Other:
Blue Spacer - 2
Green/Black Rod - 1
Step 2: Base
I put a label on each picture (bottom left or right) so you know where you are.
P1: Build this
P2: Build this
P3: Attach as shown
P4: This is what you will get.
P5: Build this
P6: Another View
P7: Attach as Shown
That's the base done. Put this to the side until step 5.
P1: Build this
P2: Build this
P3: Attach as shown
P5: Build this
P6: Another View
P7: Attach as Shown
Step 3: The Table
This is the table that the ball rolls on. For this you need the cardboard.
Small Size : 20.5 X 20.5cm
Large Size : 29.5 X 29.5cm
(These are the Dimansions of A4 paper)
P1: Build this
P2: Build this
P3: Build this
P4: Build this
P5: Attach as ahown
P6: Attach the bottom part (Black clip down)
P7: Push in the cardboard and tape where nesesary.
P1: Build this
P2: Build this
P3: Build this
P4: Build this
P5: Attach as ahown
Step 4: Roof and Layout
The Layout in this model is held up by the roof.
P1: Make one of what is on the right and at least 4 of the pieces on the left (must be an even number).
P2: Evenly space half of the long pieces along the box.
P3: Evenly space the other half, waeving them in and out.
P4 Slide on the table.
P5: This is an example of a wall. If you weave the blue rods in and out then they will not give way to the ball
Step 5: Usage Ideas
Just a couple of ideas for using it. I've told you how to make a labyrinth but you can also:
Use just the table as a boxing rink
Take the roof off and make some artwork by splashing the ball with some paint. Pop a square of paper on the cardboard and off you go!
Got any more Ideas? Post them below.
