Introduction: K'nex Tower Crane
Here is a tower crane I made one weekend that is about 75 inches (6.25 feet) tall. It has almost every function off a real tower crane. It can rotate 360 degrees, the trolley moves from the tip of the jib, all the way back to the tower, and the hook can lower all the way to the ground no matter where the trolley is. Even though the crane can only lift a few ounces, it was a build that I really enjoyed, and (if you have the pieces), I hope you will build and enjoy too! Please rate and comment! :D
Step 1: Pieces Count
This tower crane is very large and uses MANY pieces, so it would be a really good idea to make sure that you have all the pieces before you start building. Note that the count may not be 100% perfect, but should be very accurate.
Connecters:
Gray (1 slot): 3
Gray (2 slot): 6
Orange: 142
Red: 17
Green: 6
Yellow: 29
Silver Slide: 272
Blue Slide: 52
White Circle: 43
Bars/Rods:
Green: 154
White: 131
Blue: 238
Yellow: 259
Red: 151
Gray: 13
Other:
Brown/Tan Clip: 13
Blue Clip: 36
Black Hinge: 4
Blue Spacer: 50
Silver Spacer: 105
Micro Chain Gear (Black): 4
Micro Gear: 2
Large Gear: 1
Medium Gear: 2
Small Gear: 1
Big Wheel: 5
Big Tire: 0
Small Wheel: 4
Small Tire: 4
Motor: 3
Chain Links: 162
String: 20-25 feet
Marbles (optional): 70-90 (depending on size of load)
Connecters:
Gray (1 slot): 3
Gray (2 slot): 6
Orange: 142
Red: 17
Green: 6
Yellow: 29
Silver Slide: 272
Blue Slide: 52
White Circle: 43
Bars/Rods:
Green: 154
White: 131
Blue: 238
Yellow: 259
Red: 151
Gray: 13
Other:
Brown/Tan Clip: 13
Blue Clip: 36
Black Hinge: 4
Blue Spacer: 50
Silver Spacer: 105
Micro Gear: 2
Large Gear: 1
Medium Gear: 2
Small Gear: 1
Big Wheel: 5
Big Tire: 0
Small Wheel: 4
Small Tire: 4
Motor: 3
Chain Links: 162
String: 20-25 feet
Step 2: The Base
This is one of the easiest sections to build, although it could be considered the most important.
Step 3: The Tower
Okay, I lied, this is the easiest section of the crane to build :)This part attaches to the base to hold up the jib and counter weight.
Step 4: The Rotating Mechanism
This little part is what makes the whole crane rotate!
Step 5: The Top of the Tower
This will hold the jib and the counter weight on it's sides.
Step 6: The Tower Tip
Step 7: The Jib
This will hold the hook and trolley.
Step 8: The Counter Weight
This small part will balance out the crane.
Step 9: The Support Rods
These slim pieces will help distribute the weight of the jib and counter weight so they don't break off.
Step 10: The Winch
This will raise and lower the hook from the jib.
Step 11: The Trolley Mechanism
This will move the trolley along the jib.
Step 12: The Trolley
This will bring the hook along the jib.
Step 13: The Hook
This will lift the load.
Step 14: Inserting the Trolley Mechanism
This will connect the chain around through the jib.
Step 15: Stringing Up the String
This will connect to the winch and the hook.
Step 16: Assembling the Crane
This will show you how to assemble the crane.
