Introduction: Knex Type 89 TR UPGRADE {Build}
About: Look out for a new gun...
Whassup! So you've probably seen my ible about the Type 89 TR, (https://www.instructables.com/Knex-Type-89-TR) and now I've upgraded it, as well as prepared a tutorial about it, so you can build it yourself! Like it? Best is to go on to the build, but I've got some B҉o҉r҉i҉ng҉ stuff to say. I designed this gun purely because I was going outside, (you may have heard it in my previous ible) and I somehow made it better and better until I thought this was good enough to post!!! It shoots around 50-70 feet, and feels really good, except the handle is a mite too small.
Phew! Now for the build!
Note: If you want to end up precisely as I did, you must follow the instructions, but if you have any trouble, just inform me.
Step 1: Body + Barrel~
The most simple part; the most important part.
Step 2: The Rest~
The harder bit, and adding comforters on the handle; finishing it off.
Step 3: Firing Pin and Adjustments~
Now you've finally finished, you can learn to shoot it. Follow the images, then learn to load by looking the rest of the images. You get a purple connector (1-way connector) with a green rod on the end, and load it into the top of the gun. WARNING! NOT MAG FED!
I hope you built it, and if so you can easily post your build down below, maybe I don't have to explain, it's simple enough, just look...
Enjoy!
~Blitzx~
