Introduction: Knex Unbreakable Sword (Tier 3/5)
Great for if you need to break something or test the limits of other weapons. Absolutely destroys wobbly and stacked-type weapons.
Minimum Supplies:
7 Gray Rods
6 Red Rods
2 Yellow Rods (Semi-Optional)
6 White Connectors (Semi-Optional To Be Swapped With Navy Blue)
14 Navy Blue Connectors
75 Blue Spacers
Step 1: Handle
(1) Connect 4 of the navy blue connectors onto the first grey rod in a staircase-like pattern to avoid uneven grip on it.
(2) Connect another gray rod onto the spiral, but 2 to the right.
(3) Follow the pattern of the 3rd Image.
(4) Connect 3 rods to the Handle. Push it down. (For now)
(5) Put 5 white connectors onto the gray rods, remember to space them from the 3 places previously.
(6) space the white parts out, and press the red pieces into place. A weight of 5-10 pounds might br needed to jam the red piece into the middle of the 2 grey rods. You can move the navy blue connectors up as much as you like.
Step 2: Top
(1) At the end of the 3 red rods, connect 3 white or navy blue rods onto the top. (If using navy blue, put the empty part overtop the gray rod with nothing next to it.) ((Prob better staircasing it))
(2) Hardest step. In the photo, place where a grey rod should go. You will need a weight or great grip strength, and you will meed to move stuff around and place the rod into each of the connectors 1 at a time.
(3) Now, follow the pattern.
(4) Put 2 navy blue connectors onto the top. For this and the rest of the navy blue parts, make sure the empty part is where step 2’s piece is.
Step 3: The Dangerous Part
(1) On all the grey parts at the top, put 15 blue spacers.
(2) put 2 navy blue spacers on top of the 15 blue spacers.
(3) put 10 more blue spaces on top of the 2 navy connectors.
(4) put the final navy piece on top. (I used a black octo-connector)
(5) put a red rod on all the remaining open spots, though I left one off incase I want to break apart it easier.
Step 4: Final Result.
Nice one. At 10 favorites, or when I feel like it I will make a new one. Willing to help in comments!
