Introduction: Knex Unstable Uranium Grenade
About: Hello. My name is I have an interest of making model guns with k'nex, even though I don't post much at all, I make some guns then never post or remember ever again because they are simply too complicated. I …
As anybody know this is my first original instructables the other one was thought of a copy since it was like another grenade. Anyway, this is the second grenade I have made.
I have dubbed this the "KNEX UNSTABLE URANIUM GRENADE" because 1. It is unstable. 2. it works like a uranium grenade, having a piece blocked by somehting and then releasing it causing atoms to hit each other making total awesomeness.
This grenade can hit up to 15 feet and uses spacers.
*Update* To make a pin put a light 2 spot grey spacer just below where the spacers are apush upwars 'till tight. Take it out and pull down the spacers to arm it.
Step 1: Pieces Needed
Simple and Easy.
To make the block thingy you need 20, 15 or 10 red connectors (20 is reccommended, works better),20,15 or 10 green rods and 4 blue rods. Connect 4 red connectors and 4 green rods together to make a square. Now repeat 4,3 or 2 times.use the blue rod to ronnect it in the middle. This serves as the outer shell whic can break knex weponry and be reused.
Sorry, for the inconvenience of making it, my next instructable will teach you how to make it. And my newer instrucables will use that block.
Just read off the pics.
the second picture is the block.
Step 2: Makey Makey
1. Make the pin
2. Put on shrapnel
3. Slide a orange connector on one of the diagonal blkue rods sticking out on the square.
4. put the pin throuh so it looks like when you put your fingler through a fingerloop.
5. Add rubber bands
Step 3: Atomic Explowsion
Pull back on the pin and put the blocker in front so that some of the pin is still in there but it canot excape out. Ok now hold on the orange bit sticking out*******, hold it vertically, slide down the shrapnel and throw. Sometimes if it doesnt land properly the back of pin will corrupt and leave a smaller mess
Step 4: Some Other Fun
Try to move your mouse into the centre box it will show the website for the best knex gun in the world. Low piece rate, no friction barrel and min power 200 ft without any broken pieces.
