Introduction: Knex Working Simple Clock
I had an idea for a knex clock that no one had used before. A blue gear spinning a big gear. The small gear spins fast and when the big yellow gear was spinning it span slowly and if you attach something to the yellow gears rod it span about 1 slot every second. And before we make, let me explain why the name is so long. It was a ‘Working Clock’ because it kept track of time accurate to the second. It was ‘simple’ because it only used 2 gears in the entire clock. In lowny’s version it used more than 5 gears and 1000 pieces! Mine only uses about 250 pieces. The clock works by the motor spinning the small blue gear, and that gear slowly spins the big yellow gear and that big gear spins slowly and the rod in which the gear is placed is attached to the white con and the connecter is what keeps track of time. The black cap (pic 2) is also used to keep time. Every time a green or a white rod passes though the black cap a second has passed.
Pros and con time!!!!
PROS
Piece efficient
Works very well
Moddable
Accurate timing
CONS
The outer layer looks terrible. (Please fix and post the link in the comment section).
And for the first time, Please leave a comment and favorite and remember SUBSCRIBE!!!!
PROS
Piece efficient
Works very well
Moddable
Accurate timing
CONS
Step 1: Mech
Hardest part. But you can do it though!!
I hope the pile of pictures that I took were enough.
Step 2: Cover
Easy. Make from the pictures. I took a lot of pictures just in case.
Step 3: Assembly
Connect.
Step 4: Creator0479 Out!
Thank you all for watching and have a wonderful day.
